08-14-2017, 11:24 | #46 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
08-14-2017, 11:49 | #48 (permalink) | |
Major Poster Join Date: Apr 2017
Member: 2711575 Status: Offline Thanks Meter: 8 | Quote:
i gave up on z3x! it'd brick all my frps half-way, got me resorting to the blessed RealTerm! cant hold back my hard feelings for a team id draw inspiration from! i actually feel z3x betrayed me by becoming just another copy/paster | |
08-14-2017, 12:06 | #53 (permalink) |
Freak Poster Join Date: Oct 2008 Location: cubao
Member: 883685 Status: Offline Sonork: 100.1648291 Thanks Meter: 53 | sir blang i have private message for you please check... i try to pm you again but your inbox is full. or send me your email or any i can contact you like skype or wechat. please check bro, Br, Alexaliah Gsm |
08-14-2017, 14:47 | #58 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | nobody force you use z3x. who is copy/paster, who is real creator of solution everybody know on this forum without your comment. |
The Following 4 Users Say Thank You to blang For This Useful Post: |
08-14-2017, 14:48 | #59 (permalink) |
Junior Member Join Date: May 2013
Member: 1949294 Status: Offline Thanks Meter: 0 | pls what can be done, i was reading code via server and got this UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Read Codes via Server Selected model: SM-G930A Selected port: COM143 SAMSUNG Mobile USB Serial Port Software version: 29.0 Checking Login and Password... OK Ballance: 5 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G930A Android version: 7.0 Product code: SM-G930AZKAATT Phone version: G930AUCS4BQE1 PDA version: G930AUCS4BQE1 CSC version: G930AATT4BQE1 CSC country code: USA CSC sales code: ATT HW version: REV0.6 Phone SN: R58H81YQA1P Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-05-01 RF cal date: 2016.08.12 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM22 detected Reading data from phone... error (3) Done with Samsung Tool PRO v.29.0 |
08-14-2017, 14:50 | #60 (permalink) | |
by the way if you have problem - open own thread with correct name and wait for answer. | |
