11-13-2017, 08:57 | #103 (permalink) |
Insane Poster Join Date: Jan 2008 Location: California USA
Member: 693376 Status: Offline Thanks Meter: 5 | J330FN reading data from phone error at different percentage I managed to get it read at most 45% then error, mostly error under 9% Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM17 Reading phone info... OK Model: SM-J330FN AP version: J330FNXXU1AQI1 CSC version: J330FNVFG1AQI1 CP version: J330FNXXU1AQF7 Product code: VD2 Phone SN: R58J73ZGGWE Unique number: CQE0026F0E4E964 Searching Samsung diag port... detected COM30 Reading phone info... OK CP version: J330FNXXU1AQF7 CP build: Jun 15 2017 15:50:55 Reading data from phone... error (19) Done with Samsung Tool PRO v.29.7.2 |
11-13-2017, 09:50 | #104 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ROMANIA
Member: 188484 Status: Offline Thanks Meter: 117 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-J330FN Software version: 29.7 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM22 Reading phone info... OK Model: SM-J330FN AP version: J330FNXXU1AQI1 CSC version: J330FNVFG1AQI1 CP version: J330FNXXU1AQF7 Product code: CNX Phone SN: R58J75H071R Unique number: CQE00A40FCEDD64 Searching Samsung diag port... detected COM21 Reading phone info... OK CP version: J330FNXXU1AQF7 CP build: Jun 15 2017 15:50:55 Reading data from phone... error (3) Done with Samsung Tool PRO v.29.7 |
