Old 11-13-2017, 22:00   #121 (permalink)
Crazy Poster
Member: 531765
Thanks Meter: 9
j727u error
unlock error server {01} j727u
sonork sr 100.1679355
Old 11-13-2017, 22:31   #122 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,515
show full log if you want help. use last version 29.8
Old 11-13-2017, 22:41   #123 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Originally Posted by kelexy10 View Post
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will apear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
If you have it voided (0x01(void)), then you can't unlock this phone using sever.
1. Power on the phone.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings)
Operation: Read Codes via Server
Selected model: SM-J330FN
Software version: 29.7.2
Checking Login and Password... OK
Ballance: 5 crd.
You have 5 credit(s) left. This opreratin takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM440
Reading phone info... OK
Model: SM-J330FN
AP version: J330FNXXU1AQF9
CSC version: J330FNBTU1AQF2
CP version: J330FNXXU1AQF7
Product code: BTU
Phone SN: R58J86S0JFN
Unique number: CQE00DBA9D70084
Searching Samsung diag port... detected COM439
CP build: Jun 15 2017 15:50:55
Reading data from phone... error (1)
Done with Samsung Tool PRO v.29.7.2
please try 29,8 version. Must work.
The Following User Says Thank You to blang For This Useful Post:
Old 11-13-2017, 23:36   #124 (permalink)
Member: 1484663
Thanks Meter: 344
Hi, my reseller it's selling credits packs of 62 credits. It's any service costing 1 or 2 credits?? BR
Old 11-13-2017, 23:42   #125 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
this is used pack. exist 30 50 100 150
Old 11-13-2017, 23:53   #126 (permalink)
Member: 2118696
Thanks Meter: 16
Unable to unlock sim servive provider SM-J727U 7.0 Codes doesnt works
I read unlock codes via servers but when i try to unlock the phone says unable to unlock sim service provider, tried all codes Network lock, SP, Freeze code , non works
Please help me
[ 13/11/2017 11:11:00 a.m. ] Operation: Read Codes via Server
[ 13/11/2017 11:11:00 a.m. ] Selected model: SM-J727U
[ 13/11/2017 11:11:00 a.m. ] Software version: 29.7
[ 13/11/2017 11:11:00 a.m. ] Checking Login and Password... OK
[ 13/11/2017 11:11:00 a.m. ] Ballance: 10 crd.
[ 13/11/2017 11:11:00 a.m. ] You have 10 credit(s) left. This opreratin takes 5 credits.Continue? Yes
[ 13/11/2017 11:11:00 a.m. ] Searching Samsung modem... detected COM1175
[ 13/11/2017 11:11:00 a.m. ] Reading phone info... OK
[ 13/11/2017 11:11:00 a.m. ] Model: SM-J727U
[ 13/11/2017 11:11:00 a.m. ] AP version: J727UUEU1AQF2
[ 13/11/2017 11:11:00 a.m. ] CSC version: J727UOYM1AQF2
[ 13/11/2017 11:11:00 a.m. ] CP version: J727UUEU1AQF2
[ 13/11/2017 11:11:00 a.m. ] Product code: XAA
[ 13/11/2017 11:11:00 a.m. ] Phone SN: R28J50D0JWW
[ 13/11/2017 11:11:00 a.m. ] Unique number: C00006D8250EEA3
[ 13/11/2017 11:11:00 a.m. ] Searching Samsung diag port... detected COM1176
[ 13/11/2017 11:11:00 a.m. ] CP build: Jun 15 2017 13:49:50
[ 13/11/2017 11:11:00 a.m. ] Reading data from phone... OK
[ 13/11/2017 11:12:00 a.m. ] Calculating... OK
[ 13/11/2017 11:12:00 a.m. ] Searching server... OK
[ 13/11/2017 11:13:00 a.m. ] Waiting for server answer... OK
[ 13/11/2017 11:13:00 a.m. ] Freeze code: 74074048
[ 13/11/2017 11:13:00 a.m. ] NET lock: 40350397
[ 13/11/2017 11:13:00 a.m. ] SUB lock: 00000000
[ 13/11/2017 11:13:00 a.m. ] SP lock: 50953819
[ 13/11/2017 11:13:00 a.m. ] CP lock: 00000000
[ 13/11/2017 11:13:00 a.m. ] SIM lock: 00000000
[ 13/11/2017 11:13:00 a.m. ] For check lock status: *#7465625#
Old 11-14-2017, 02:00   #127 (permalink)
Member: 2207819
Thanks Meter: 24
J727az
Mr. Blang any ideas on this:
Searching Samsung modem... detected COM277
Model: SM-J727AZ
AP version: J727AZTUU1AQE1
CSC version: J727AZAIO1AQE1
CP version: J727AZTUU1AQE1
Product code: AIO
Phone SN: R28J61NTJ3R
Unique number: C000XXXXXXX57A3
Searching Samsung diag port... detected COM278
CP build: May 15 2017 18:47:48
Reading data from phone... error (19)
Old 11-14-2017, 02:15   #128 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Please help me
show photo of display.
Old 11-14-2017, 02:16   #129 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Model: SM-J727AZ
Product code: AIO
use last version of samsung tool 29.8
Old 11-14-2017, 02:48   #130 (permalink)
Member: 2179862
Thanks Meter: 17
No Download
The versión 29.8 seems not to be available. I was trying during the last hour to download through Shell and nothing happens. Can you please provide a link where can I download it?
I tried to download through Z3X team webpage, but it asks for Shell and it doesn´t work, so webpage is not an option either.
Old 11-14-2017, 03:36   #131 (permalink)
Member: 1900730
Thanks Meter: 188
same error, can't download the 29.8 from shell.
Old 11-14-2017, 03:41   #132 (permalink)
APZ
Registered User
Member: 382531
Thanks Meter: 2
Same with me i updated last night with another computer that was OK I can't with this computer so there must be something wrong i can't download from the website either.
Old 11-14-2017, 04:52   #133 (permalink)
Member: 241855
Sonork: 1623913
Thanks Meter: 89
Pls whatis wrong as I try reading code on a s8+ but software saying I should update and I did already no update available and after says password incorrect I never had these issues before it read info and credit and code well and I still used it 2 days ago
The Following User Says Thank You to olubolajames For This Useful Post:
Old 11-14-2017, 05:15   #134 (permalink)
Taguro-GSMLover's Avatar
Member: 2669319
Thanks Meter: 421
It seems Samsung Tool Pro 29.8 exe maybe on shell has a problem now. I can't DL latest setup for Samsung Toolpro.
Old 11-14-2017, 06:11   #135 (permalink)
solusi hp's Avatar
Member: 2162000
Sonork: 100.1670061
Thanks Meter: 205
any link or mirror i can not download via shell or support
Page generated in 0.24656 seconds with 8 queries
