Old 11-14-2017, 05:38   #136 (permalink)
Member: 563008
Thanks Meter: 58
Yes it's true.Downloading 29.8 via shell does not work but you can download and install via Samsung tool pro 29.7
Or you can use this
http://www.mediafire.com/file/bhb058...olPRO_29.8.exe
Thanks to Raisalina
The Following 6 Users Say Thank You to pashamangl For This Useful Post:
Old 11-14-2017, 07:41   #137 (permalink)
Member: 693376
Thanks Meter: 4
29.8 did the trick thanks for support
Operation: Read Codes via Server
Selected model: SM-J330FN
Software version: 29.8
Checking Login and Password... OK
Ballance: 40 crd.
You have 40 credit(s) left. This opreratin takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM17
Reading phone info... OK
Model: SM-J330FN
AP version: J330FNXXU1AQI1
CSC version: J330FNVFG1AQI1
CP version: J330FNXXU1AQF1
Product code: VD2
Phone SN: R58J73ZGGWE
Unique number: CQE0026F0E4E964
Searching Samsung diag port... detected COM30
CP build: Jun 1 2017 14:22:06
Reading data from phone... OK
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 83502470
NET lock: 51302850
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.29.8
The Following User Says Thank You to giaguaro For This Useful Post:
Old 11-14-2017, 07:52   #138 (permalink)
Member: 1972804
Thanks Meter: 17
it worked
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will apear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
If you have it voided (0x01(void)), then you can't unlock this phone using sever.
1. Power on the phone.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings)
Ballance: 50 crd.
You have 50 credit(s) left. This opreratin takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM440
Model: SM-J330FN
AP version: J330FNXXU1AQF9
CSC version: J330FNBTU1AQF2
CP version: J330FNXXU1AQF7
Product code: BTU
Phone SN: R58J86S0JFN
Unique number: CQE00DBA9D70084
Searching Samsung diag port... detected COM439
CP build: Jun 15 2017 15:50:55
Calculating... OK
Freeze code: 57315971
NET lock: 47040957
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 11-14-2017, 11:18   #139 (permalink)
Member: 871125
Sonork: 1607190
Thanks Meter: 68
Thanks Z3X...
Ballance: 40 crd.
Searching Samsung modem... detected COM24
Model: SM-A520F
AP version: A520FXXS2BQIJ
CSC version: A520FOXA2BQI1
CP version: A520FXXU2AQF7
Product code: BTU
Phone SN: R58J135F72X
Unique number: CBJ10ED6B64FBB3
Searching Samsung diag port... detected COM23
CP build: Jun 13 2017 04:36:14
Calculating... OK
Freeze code: 81586491
NET lock: 24753615
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
The Following User Says Thank You to aliraxa For This Useful Post:
Old 11-14-2017, 15:24   #140 (permalink)
Member: 2118696
Thanks Meter: 10
Originally Posted by blang View Post
show photo of display.
Tried Freeze code first then network code no worked, =Tried Freeze code first then SP code neither worked
Old 11-14-2017, 17:05   #141 (permalink)
Member: 2118696
Thanks Meter: 10
Link Photos
https://ibb.co/nkO57b
https://ibb.co/j6Wgfw
https://ibb.co/fg5k7b
https://ibb.co/g1PCnb
Old 11-14-2017, 22:11   #142 (permalink)
Member: 2147383
Thanks Meter: 50
Ballance: 20 crd.
You have 20 credit(s) left. This opreratin takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM55
Model: SM-G950F
AP version: G950FXXU1AQH3
CSC version: G950FOVF1AQH3
CP version: G950FXXU1AQH3
Product code: VOD
Phone SN: RF8J41JMZBP
Unique number: CE03171338C3885F0C
Searching Samsung diag port... detected COM54
CP build: Aug 8 2017 23:17:44
Calculating... OK
Freeze code: 28152516
NET lock: 91316315
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 11-15-2017, 07:04   #143 (permalink)
Member: 473386
Thanks Meter: 24
How unlock SM-G955F, in unlock tab no button via server? - support SM-G955F (Direct read codes via server) - First in the world
Old 11-15-2017, 07:39   #144 (permalink)
Member: 473386
Thanks Meter: 24
Sorry, all ok , autoupdate not update software and was 29.6 )))
2 sucsess unlock SM-G955F
Selected model: SM-G955F
Ballance: 25 crd.
You have 25 credit(s) left. This opreratin takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM115
Model: SM-G955F
AP version: G955FXXU1AQEB
CSC version: G955FOXM1AQEB
CP version: G955FXXU1AQEB
Product code: DBT
Phone SN: R58J60G8NYP
Unique number: CE0517157973E32C02
Searching Samsung diag port... detected COM114
CP build: May 19 2017 19:19:00
Calculating... OK
Freeze code: 59462715
NET lock: 29497157
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
2nd
Ballance: 30 crd.
You have 30 credit(s) left. This opreratin takes 5 credits.Continue? Yes
Searching Samsung modem... detected COM117
Model: SM-G955F
AP version: G955FXXU1AQH3
CSC version: G955FOXM1AQH3
CP version: G955FXXU1AQH3
Product code: XEO
Phone SN: R58J75J0H8Z
Unique number: CE051715A1DB621E02
Searching Samsung diag port... detected COM116
CP build: Aug 8 2017 23:18:01
Calculating... OK
Freeze code: 16497197
NET lock: 15025909
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 11-15-2017, 10:26   #145 (permalink)
rubel1991's Avatar
Member: 1233793
Thanks Meter: 21
card not found problem help me sir,
my card info
Card SN - AABE9E0C
Card Type - New Top Card
Card version - 2.2
Reseller: gsmsources
Card activated - 2017-07-20
Old 11-15-2017, 11:15   #146 (permalink)
sikandar.mehdi's Avatar
Member: 2080403
Sonork: 100.1645596
Thanks Meter: 45
Samsung Tool PRO 29.7 Update. First in the world New SHANNON based phones read codes.
After months of research we present new 1st world exclusive solution for read codes from SHANNON cpu based new phones. - First in the world
Important thing: KNOX must be 0!!! If knox = 1 you can not read codes!!!!!
Added:
- support SM-J727A (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-J727AZ (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-J727S (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-J727U (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-T395N (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SC-04J (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-A720S (Flashing, Read/Write EFS, Unlock via MSL, Direct READ codes via server, reboot download/recovery) - First in the world
- support SM-N950F (Flashing, Read/Write EFS, Unlock via MSL, Direct READ codes via server, reboot download/recovery) - First in the world
- support SM-N950N (Flashing, Read/Write EFS, Unlock via MSL, Direct READ codes via server, reboot download/recovery) - First in the world
- support SM-J327W (Flashing, Read/Write EFS, Unlock via MSL, Direct READ codes via server, reboot download/recovery) - First in the world
- support SM-J330N (Flashing, Read/Write EFS, Unlock via MSL, Direct READ codes via server, reboot download/recovery) - First in the world
- support SM-A320F (Direct read codes via server) - First in the world
- support SM-A320FL (Direct read codes via server) - First in the world
- support SM-A320Y (Direct read codes via server) - First in the world
- support SM-A520F (Direct read codes via server) - First in the world
- support SM-A520K (Direct read codes via server) - First in the world
- support SM-A520L (Direct read codes via server) - First in the world
- support SM-A520S (Direct read codes via server) - First in the world
- support SM-A520W (Direct read codes via server) - First in the world
- support SM-A720F (Direct read codes via server) - First in the world
- support SM-G390F (Direct read codes via server) - First in the world
- support SM-G390Y (Direct read codes via server) - First in the world
- support SM-G390W (Direct read codes via server) - First in the world
- support SM-G570F (Direct read codes via server) - First in the world
- support SM-G570M (Direct read codes via server) - First in the world
- support SM-G570Y (Direct read codes via server) - First in the world
- support SM-G610K (Direct read codes via server) - First in the world
- support SM-G610L (Direct read codes via server) - First in the world
- support SM-G610M (Direct read codes via server) - First in the world
- support SM-G610S (Direct read codes via server) - First in the world
- support SM-G610Y (Direct read codes via server) - First in the world
- support SM-G950F (Direct read codes via server) - First in the world
- support SM-G950N (Direct read codes via server) - First in the world
- support SM-G955N (Direct read codes via server) - First in the world
- support SM-J326AZ (Direct read codes via server) - First in the world
- support SM-J327A (Direct read codes via server) - First in the world
- support SM-J327AZ (Direct read codes via server) - First in the world
- support SM-J327U (Direct read codes via server) - First in the world
- support SM-J330F (Direct read codes via server) - First in the world
- support SM-J330FN (Direct read codes via server) - First in the world
- support SM-J330G (Direct read codes via server) - First in the world
- support SM-J330L (Direct read codes via server) - First in the world
- support SM-J530F (Direct read codes via server) - First in the world
- support SM-J530FM (Direct read codes via server) - First in the world
- support SM-J530G (Direct read codes via server) - First in the world
- support SM-J530GM (Direct read codes via server) - First in the world
- support SM-J530K (Direct read codes via server) - First in the world
- support SM-J530L (Direct read codes via server) - First in the world
- support SM-J530S (Direct read codes via server) - First in the world
- support SM-J530Y (Direct read codes via server) - First in the world
- support SM-J530YM (Direct read codes via server) - First in the world
- support SM-J701F (Direct read codes via server) - First in the world
- support SM-J701M (Direct read codes via server) - First in the world
- support SM-J701MT (Direct read codes via server) - First in the world
- support SM-J730F (Direct read codes via server) - First in the world
- support SM-J730FM (Direct read codes via server) - First in the world
- support SM-J730G (Direct read codes via server) - First in the world
- support SM-J730GM (Direct read codes via server) - First in the world
- support SM-J730K (Direct read codes via server) - First in the world
- support SM-P585 (Direct read codes via server) - First in the world
- support SM-P585M (Direct read codes via server) - First in the world
- support SM-P585N0 (Direct read codes via server) - First in the world
- support SM-P585Y (Direct read codes via server) - First in the world
- support SM-P587 (Direct read codes via server) - First in the world
- support SM-P588C (Direct read codes via server) - First in the world
- support SM-T395 (Direct read codes via server) - First in the world
GUI changes:
- Fixed closing software after DB compact
- Removed "Solution" (Diagnostic data for server)
- Black skin improvements
- Link Login to current Card
(This function added for protect LOGIN/PASS from using on other CARD )
ATTENTION: PLEASE DONíT LOSE YOUR TIME WITH SHANNON PHONES IF KNOX=1.
IF KNOX=1 phone just will not answer on command. READ CODES AT THIS MOMENT NOT POSSIBLE IF KNOX=1!!!
CREDITS POLICY CHANGES:
From today the minimum pack - 30credits:
Success Read Codes Shannon phones: 5 credits.
Success Read Codes Qualcomm phones: 4 credits MEGA PROMO. ( from 00h-00m ,11 november to 13 november 23h-59m. TIME: GMT+2)
Success Read Codes Qualcomm phones: 5 credits FROM 14 november 00h-00m. TIME: GMT+2
CREDITS RESELLERS HERE
Like usually new solution may have small bug, which will be fixed shortly.
Bug report welcome.
butt my mobile not to go any mode coz instal custum blocker no recovery mode no download mode!
Old 11-16-2017, 04:26   #147 (permalink)
Member: 2763284
SAMSUNG NOTE 4 SM-N910C
when release patch cert?
Old 11-16-2017, 13:59   #148 (permalink)
abdulhaq_majroh's Avatar
Member: 1600947
Sonork: 100.1627298
Thanks Meter: 777
Sm-g532f frp remove done
Operation: Reset FRP
Selected model: SM-G532F
Software version: 29.5
Waiting ADB device... OK
Model: SM-G532F
Android version: 6.0.1
Product code: SM-G532FZDDPAK
Phone version: G532FXXU1APJ7
PDA version: G532FXWU1APK6
CSC version: G532FOJV1APK4
CSC country code: PAKISTAN
CSC sales code: PAK
HW version: MP 0.300
Phone SN: R58J26BWV8Y
Chip name: MT6737T
Modem board: MT6737T
Security patch: 2016-11-01
RF cal date: 20170228
IMEI: 357621084514068
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.29.7
Old 11-16-2017, 15:49   #149 (permalink)
asmodi's Avatar
Member: 183976
Thanks Meter: 119
Even with 29.8 can not unlock J330f
Searching Samsung modem... detected COM258
Model: SM-J330F
AP version: J330FXXU1AQG3
CSC version: J330FLUX1AQF1
CP version: J330FXXU1AQF7
Product code: LUX
Phone SN: R58J84KZ1JF
Unique number: CQE00184ED02864
Searching Samsung diag port... detected COM250
CP build: Jun 15 2017 18:46:12
Reading data from phone... error (1)
Old 11-16-2017, 17:00   #150 (permalink)
Xaker2012's Avatar
Member: 1941705
Thanks Meter: 280
Model: SM-J530F Read Codes via Server
Selected model: SM-J530F
Software version: 29.7.2
Ballance: 20 crd.
Searching Samsung modem... detected COM227
Model: SM-J530F
AP version: J530FXXU1AQF5
CSC version: J530FATO1AQE8
CP version: J530FXXU1AQF5
Product code: ATO
Phone SN: RF8J83QA6AZ
Unique number: CAJ00E0EDEE8384
Searching Samsung diag port... detected COM228
CP build: Jun 8 2017 19:10:37
Calculating... OK
Freeze code: 53680475
NET lock: 05850929
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Done with Samsung Tool PRO v.29.7.2
Page generated in 0.48012 seconds with 7 queries
