11-11-2017, 12:22 | #62 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Shadow Clone
Member: 1357650 Status: Offline Sonork: 100.1611843 Thanks Meter: 126 | S8 PLUS UNLOCK Searching Samsung modem... detected COM73 Reading phone info... OK Model: SM-G955FD AP version: G955FXXU1AQH3 CSC version: G955FOXM1AQH3 CP version: G955FXXU1AQH3 Product code: KSA Phone SN: R58J52YJM0X Unique number: CE0417140DB670C00D Searching Samsung diag port... detected COM74 Reading phone info... OK CP version: G955FXXU1AQH3 CP build: Aug 8 2017 23:18:01 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 50397393 NET lock: 49372790 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.7Searching Samsung modem... detected COM73 Reading phone info... OK Model: SM-G955FD AP version: G955FXXU1AQH3 CSC version: G955FOXM1AQH3 CP version: G955FXXU1AQH3 Product code: KSA Phone SN: R58J52YJM0X Unique number: CE0417140DB670C00D Searching Samsung diag port... detected COM74 Reading phone info... OK CP version: G955FXXU1AQH3 CP build: Aug 8 2017 23:18:01 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 50397393 NET lock: 49372790 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.7 |
The Following 3 Users Say Thank You to TestCard17 For This Useful Post: |
11-11-2017, 12:53 | #63 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ROMANIA
Member: 188484 Status: Offline Thanks Meter: 117 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-J330FN Software version: 29.7 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM22 Reading phone info... OK Model: SM-J330FN AP version: J330FNXXU1AQF9 CSC version: J330FNVFG1AQF4 CP version: J330FNXXU1AQF7 Product code: CNX Phone SN: R58J75H071R Unique number: CQE00A40FCEDD64 Searching Samsung diag port... detected COM21 Reading phone info... OK CP version: J330FNXXU1AQF7 CP build: Jun 15 2017 15:50:55 Reading data from phone... error (2) Done with Samsung Tool PRO v.29.7 error-19....error-20...error-22 what hapend? knox of phone is 0x0000 |
11-11-2017, 14:10 | #65 (permalink) |
No Life Poster Join Date: Apr 2004 Location: ORAN-ALGERIE Age: 49
Member: 64213 Status: Offline Thanks Meter: 493 | Note 8 n950f done Searching Samsung modem... detected COM89 Reading phone info... OK Model: SM-N950F AP version: N950FXXU1AQI1 CSC version: N950FOXM1AQHF CP version: N950FXXU1AQHB Product code: PHE Phone SN: R58JA1WX2TP Unique number: CE081718991F5B3C047E Searching Samsung diag port... detected COM91 Reading phone info... OK CP version: N950FXXU1AQHB CP build: Aug 17 2017 17:41:21 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 50609731 NET lock: 16090813 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.7 |
11-11-2017, 14:24 | #66 (permalink) | |
Major Poster Join Date: Apr 2016
Member: 2565910 Status: Offline Thanks Meter: 10 | Quote:
A520f repair & patch? Is coming or not mr blang? Enviado desde mi SM-A320Y mediante Tapatalk | |
The Following User Says Thank You to djbyron8a For This Useful Post: |
11-11-2017, 14:43 | #67 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
It's pretty clear, just gotta read it carefully... Buy a minimum of 30 credits (so you can't just buy 10 or 20) Successfully read codes on Shannon phones = 5 credits always! Successfully read codes on Qualcomm phones = 4 credits promo between Nov. 11-13 Successfully read codes on Qualcomm phones = 5 credits starting Nov 14 | |
The Following User Says Thank You to BillA For This Useful Post: |
11-11-2017, 15:48 | #69 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Colombia
Member: 448639 Status: Offline Thanks Meter: 165 | world first shannon cpu Searching Samsung modem... detected COM324 Reading phone info... OK Model: SM-J330F AP version: J330FXXU1AQI2 CSC version: J330FPHE1AQI1 CP version: J330FXXU1AQF7 Product code: PHE Phone SN: R58J93CRVDF Unique number: CQE00D597D6C284 Searching Samsung diag port... detected COM325 Reading phone info... OK CP version: J330FXXU1AQF7 CP build: Jun 15 2017 18:46:12 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 31749264 NET lock: 72482474 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.7 th z3x team waiting the copy pasters danger: update not for sundays only professionals unlockers |
The Following User Says Thank You to J3soft For This Useful Post: |
11-11-2017, 16:16 | #70 (permalink) |
Freak Poster Join Date: Sep 2007 Location: France
Member: 589304 Status: Offline Thanks Meter: 74 | that why l love z3x and that why i have 3 z3x box looooll Model: SM-G950F AP version: G950FXXU1AQCA CSC version: G950FOXM1AQCA CP version: G950FXXU1AQCA Product code: MAT Phone SN: RF8J40Yxxxxxx Unique number: CE0317133587A4E20C Searching Samsung diag port... detected COM6 Reading phone info... OK CP version: G950FXXU1AQCA CP build: Mar 14 2017 19:27:10 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 06416942 NET lock: 25169315 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.7 |
11-11-2017, 16:51 | #71 (permalink) |
Insane Poster Join Date: Jan 2008 Location: California USA
Member: 693376 Status: Offline Thanks Meter: 5 | J330FN reading data from phone error Checking Login and Password... OK Ballance: 45 crd. You have 45 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM233 Reading phone info... OK Model: SM-J330FN AP version: J330FNXXU1AQF9 CSC version: J330FNFTM1AQF3 CP version: J330FNXXU1AQF7 Product code: FTM Phone SN: R58J73ZGGWE Unique number: CQE0026F0E4E964 Searching Samsung diag port... detected COM234 Reading phone info... OK CP version: J330FNXXU1AQF7 CP build: Jun 15 2017 15:50:55 Reading data from phone... error (19) Done with Samsung Tool PRO v.29.7 prior to this I unlocked an G950F without prolem...please help z3x team |
11-11-2017, 19:08 | #74 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1602597 Status: Offline Sonork: MANUEL VICTOR BARRIGA LOP Thanks Meter: 1 | good afternoon I get this error when doing unlock by msl N950F Searching Samsung modem ... detected COM309 Reading phone information ... Done Model: SM-N950F AP version: N950FXXU1AQH9 CSC version: N950FOXM1AQH9 CP version: N950FXXU1AQH9 Product Code: PHE Phone SN: R58J858D9WE Unique number: CE06171655B70D1F027E Reading IMEI ... Ready Reading SN ... error (1) Done with Samsung Tool PRO v.29.7 |
11-11-2017, 19:17 | #75 (permalink) |
Insane Poster Join Date: Jun 2014
Member: 2207819 Status: Offline Thanks Meter: 24 | J727AZ Unlock Error Hey just leaving this here for DEVS to take a look: Operation: Unlock Selected model: SM-J727AZ Software version: 29.7 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-J727AZ Android version: 7.0 Product code: SM2J727AZKZAIO Phone version: J727AZTUU1AQE1 PDA version: J727AZTUU1AQE1 CSC version: J727AZAIO1AQE1 CSC country code: USA CSC sales code: AIO HW version: REV0.7 Phone SN: R28J61NTJ3R Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-05-01 RF cal date: 20170616 IMEI: XXXXXXXXXXXXX5 Checking Super user right... false Root your phone manually and then repeat Done with Samsung Tool PRO v.29.7 |
