11-13-2017, 10:14 | #106 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1972804 Status: Offline Thanks Meter: 26 | please help Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-J330FN Software version: 29.7.2 Checking Login and Password... OK Ballance: 5 crd. You have 5 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM440 Reading phone info... OK Model: SM-J330FN AP version: J330FNXXU1AQF9 CSC version: J330FNBTU1AQF2 CP version: J330FNXXU1AQF7 Product code: BTU Phone SN: R58J86S0JFN Unique number: CQE00DBA9D70084 Searching Samsung diag port... detected COM439 Reading phone info... OK CP version: J330FNXXU1AQF7 CP build: Jun 15 2017 15:50:55 Reading data from phone... error (1) Done with Samsung Tool PRO v.29.7.2 |
11-13-2017, 10:39 | #107 (permalink) | |
Freak Poster Join Date: Sep 2008 Location: Ibadan
Member: 855615 Status: Offline Thanks Meter: 10 | Quote:
11-13-2017, 15:19 | #109 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Operation: Read Codes via Server Selected model: SM-J330FN Software version: 29.7.2 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM80 Reading phone info... OK Model: SM-J330FN AP version: J330FNXXU1AQI1 CSC version: J330FNVFG1AQI1 CP version: J330FNXXU1AQF1 Product code: CNX Phone SN: R58JA0G4DLL Unique number: CQE00E8FCD83A94 Searching Samsung diag port... detected COM79 Reading phone info... OK CP version: J330FNXXU1AQF1 CP build: Jun 1 2017 14:22:06 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 42470508 NET lock: 13792792 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.7.2 |
The Following User Says Thank You to maremestera For This Useful Post: |
11-13-2017, 15:48 | #110 (permalink) | |
Insane Poster Join Date: Jan 2008 Location: California USA
Member: 693376 Status: Offline Thanks Meter: 5 | Can you please share modem file j330fnxxu1aqf1? Can you please share modem file j330fnxxu1aqf1? Quote:
11-13-2017, 16:35 | #112 (permalink) |
Member: 871125 Status: Offline Sonork: 1607190 Thanks Meter: 83 | Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM24 Reading phone info... OK Model: SM-A520F AP version: A520FXXS2BQIJ CSC version: A520FOXA2BQI1 CP version: A520FXXU2AQI2 Product code: BTU Phone SN: R58J135XXXX Unique number: CBJ10ED6B64XXX Searching Samsung diag port... detected COM23 Reading phone info... OK CP version: A520FXXU2AQI2 CP build: Sep 6 2017 09:54:18 Reading data from phone... error (3) Done with Samsung Tool PRO v.29.7.2 |
11-13-2017, 18:37 | #114 (permalink) |
Junior Member Join Date: Jun 2016 Location: Mexico
Member: 2586721 Status: Offline Thanks Meter: 12 | I need install software in a new directory...how can i do it? Always install in a previous directory and replace the files of a previous version, i cant choose another directory, how can i change it? |
11-13-2017, 18:44 | #116 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | Quote:
or 2. Download 19.1 version launch, select and install to a "New Directory", Afterwards launch latest setup it will automatically installed to the "New Directory" and from now on all latests setups will be installed to the "New Directory" | |
11-13-2017, 18:47 | #117 (permalink) |
Member: 693376 Status: Offline Thanks Meter: 5 | connected as described still got error what am I doing wrong? flashed different firmware,and also modem from comination file, still error: Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM17 Reading phone info... OK Model: SM-J330FN AP version: J330FNXXU1AQI1 CSC version: J330FNVFG1AQI1 CP version: J330FNXXU1AQF1 Product code: VD2 Phone SN: R58J73ZGGWE Unique number: CQE0026F0E4E964 Searching Samsung diag port... detected COM30 Reading phone info... OK CP version: J330FNXXU1AQF1 CP build: Jun 1 2017 14:22:06 Reading data from phone... error (20) Done with Samsung Tool PRO v.29.7.2 |
11-13-2017, 19:05 | #118 (permalink) |
Member: 871125 Status: Offline Sonork: 1607190 Thanks Meter: 83 | I Have read your solution and implemented it as well but no joy.i tried all the modems available in download sections but still read code error.After applying all the solution i did that earlier post so that z3x could fix the problem. |
11-13-2017, 19:35 | #120 (permalink) |
Member: 2586721 Status: Offline Thanks Meter: 12 | Always Rename Folder...its a waste of time, the LG and MTK version can change directory in the update, only Samsung Tool Pro "updates" the directory... Thanks anyway |
