z3x box First in the world ok |
thanks for big update but in our country we need imei repair patch cert please time is working that thank you |
sir read codes diag done but sir net lock not work please solve it Checking hash file... OK Searching Samsung modem... detected COM428 Reading phone info... OK Model: SM-A510FD AP version: A510FXXU4CQG7 CSC version: A510FDOJP4CQG1 CP version: A510FDXXU4CQDL Product code: MID Phone SN: R58H82T3CPR Unique number: C0000B335A96D43 Searching Samsung diag port... detected COM429 Reading phone info... OK CP version: A510FDXXU4CQDL CP build: Apr 24 2017 17:53:49 Reading data from phone... Reading NV data... OK Modem board: SHANNON310 Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:07) Freeze code: 27952731 NET lock: 71728977 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.9 |
after click read codes DIAG UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes DIAG Selected model: SM-J710MN Software version: 29.9 Checking hash file... Exception: File access denied Done with Samsung Tool PRO v.29.9 |
biggest update in tha gsm world. we love z3x team products, love u lots, :cool::cool:. many many thanks z3x team ,:):):). only z3x is KIng of all gsm prducts, |
Kindly add model Samsung S727vl(GP) sky pro for network unlock for the next update please as of now we cannot unlock this unit |
UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-J710MN Software version: 29.9 Searching Samsung modem... detected COM11 Reading phone info... OK Model: SM-J710MN AP version: J710MNUBU1API5 CSC version: J710MNUWE1API5 CP version: J710MNUBU1APG7 Product code: SM-J710MZWNBAT Phone SN: RF8HC2K2L4M Unique number: CAJ03F80C4D7AB3 Reading IMEI... OK IMEI: 359587073316492 (SIGN: OK) Checking hash file... Exception: File access denied Done with Samsung Tool PRO v.29.9 help me mister blang |
sir freeze code done Quote:
sir freeze code done but net lock not done:confused::confused: |
great update z3x team very usefull with out root read codes |
Operation: Read Codes DIAG Selected model: SM-G610F Software version: 29.9 Checking hash file... OK Searching Samsung modem... detected COM401 Reading phone info... OK Model: SM-G610F AP version: G610FDXU1BQH7 CSC version: G610FOLB1BQI2 CP version: G610FDDU1API9 Product code: XME Phone SN: R58******* Unique number: CBJ109489411D64 Searching Samsung diag port... detected COM400 Reading phone info... OK CP version: G610FDDU1API9 CP build: Sep 19 2016 17:53:04 Reading data from phone... Reading NV data... OK Modem board: SHANNON315 Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:02) Freeze code: 73174818 NET lock: 24291747 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.9 THANKS Z3X TEAM NO NEED ROOT NO NEED CREDIT |
big update thanks, please add security repair option for g920f etc.. |
Z3X-BOX Samsung PRO Update. Samsung Tool 29.9 Update. Read codes without server added First in the world Z3X (Read CERT DIAG) if knox - 0. No root need. Type *#0808# and select 'DM+ACM+ADB Samsung Galaxy Note 8 successful Read cert Done Searching Samsung modem... detected COM52 Reading phone info... OK Model: SM-N950F AP version: N950FXXU1AQI1 CSC version: N950FOXM1AQHF CP version: N950FXXU1AQHB Product code: XEU Phone SN: R58J83JQYMF Unique number: CE051715DDFA473C027E Searching Samsung diag port... detected COM53 Reading phone info... OK CP version: N950FXXU1AQHB CP build: Aug 17 2017 17:41:21 Reading data from phone... OK Calculating... OK Certificate file saved to C:\Program Files (x86)\Z3X\Samsung\SamsungToolPRO\ backup\Cert\SM-N950F_R58J83XXXXX_35200XXXXXXXXXX_20-11-2017_13-22-3.cert Done with Samsung Tool PRO v.29.9 http://i63.tinypic.com/208y87k.jpg THANKS...........Z3X-Team Products. |
The best in samsung field The great will be be great for ever . Nice update. |
