04-29-2016, 01:46 | #3 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1823774 Status: Offline Sonork: Hu33ein Thanks Meter: 2 | hi guys if you want to unlock this model with z3x do this : To connect SGH-T899M phone you have to perform the following steps: 1. Disconnect cable from phone. 2. Go to dial window. 3. Enter ##634# number. 4. Input *#7284# code. 5. Select "QC RmNetComposite" option. 6. Press "OK" button. 7. Wait until phone restart. 8.connect to pc then install drivers ! 9. choose on Z3X model SGH-I317 then choose Selected port: COM81xx Qualcomm HS-USB Diagnostics 9001 Software version: 25.2 Then click unlock and see its done Reading phone info... Reading IMEI... OK IMEI: 3543410501******* Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.2 thanks |
04-29-2016, 01:48 | #4 (permalink) |
Member: 1823774 Status: Offline Sonork: Hu33ein Thanks Meter: 2 | how to unlock sgh-t899m with Z3X done !!by Yani hi guys if you want to unlock this model with z3x do this : To connect SGH-T899M phone you have to perform the following steps: 1. Disconnect cable from phone. 2. Go to dial window. 3. Enter ##634# number. 4. Input *#7284# code. 5. Select "QC RmNetComposite" option. 6. Press "OK" button. 7. Wait until phone restart. 8.connect to pc then install drivers ! 9. choose on Z3X model SGH-I317 then choose Selected port: COM81xx Qualcomm HS-USB Diagnostics 9001 Software version: 25.2 Then click unlock and see its done Reading phone info... Reading IMEI... OK IMEI: 3543410501******* Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.2 thanks |
11-18-2016, 18:51 | #5 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Need Help with T899M Quote:
The Following User Says Thank You to beerfoote1 For This Useful Post: |
10-25-2018, 15:34 | #7 (permalink) |
Junior Member Join Date: Dec 2015 Location: Mumtazabad,Multan,Punjab,Pak
Member: 2502347 Status: Offline Thanks Meter: 4 | Thankful Bro For u U r great Bro Thanks A lot[UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SGH-I337 Selected port: COM131 Qualcomm HS-USB Diagnostics 9001 Software version: 34.0 Reading phone info... Reading IMEI... OK IMEI: 354054050232122 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.34.0][/QUOTE] Last edited by Rashid_786; 10-25-2018 at 15:40. Reason: Adding image of work |
