03-13-2018, 03:53 | #92 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2815139 Status: Offline Thanks Meter: 2 | Hello I perform all the process correctly without giving any error download normal firmware "J710MNUBU4BRA1_UUB4BRA1" from 4 parts of the database z3x realize flash in SM-J710MN repair imei, certified patch but still no signal here attached the last process done help please!!! Operation: Patch Certificate Selected model: SM-J710MN Software version: 30.9 Waiting ADB device... Por favor, permite la depuración USB en el teléfono... Listo Leyendo información del teléfono ... Modelo: SM-J710MN Android version: 7.0 Código del Producto: SM-J710MZWNTTT Versión del telefono: J710MNUBU4BRA1 PDA version: J710MNUBU4BRA1 CSC version: J710MNUUB4BRA1 Código de país CSC: TRINIDAD AND TOBAGO Código de Venta CSC: TTT HW version: MP 0.300 Phone SN: R28JA1XXGRP Chip name: EXYNOS7870 Módem: SHANNON315 Security patch: 2018-01-01 RF cal date: 20171020 IMEI: 359586081880929 Verificando derecho de Super Usuario... verdadero Reading NV data... Listo Checking NV data... Listo Reading data... Listo Detecting MODEM... Listo Reading MODEM... Listo Calculando... Listo Initialization data... Listo Writing zTool... Listo Initialization zTool... Listo Reiniciando teléfono ... Listo Patching CERT check... hecho Done with Samsung Tool PRO v.30.9 |
03-13-2018, 04:46 | #93 (permalink) |
Freak Poster Join Date: Oct 2009 Location: Development World
Member: 1145580 Status: Offline Sonork: 100.1602311 Thanks Meter: 60 | Operation: Repair Selected model: SM-J701M Software version: 30.9 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J701M Android version: 7.0 Product code: SM-J701MZKJCOO Phone version: J701MUBU2AQL2 PDA version: J701MUBU2AQL3 CSC version: J701MUUB2AQL2 CSC country code: Colombia CSC sales code: COO HW version: MP 0.400 Phone SN: RF8JB0TVFKP Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-12-01 RF cal date: 20171107 IMEI: 351574093XXXXXX Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1) Initialization zTool... error (0 1) Done with Samsung Tool PRO v.30.9 |
03-13-2018, 10:01 | #94 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Well, can't you see? CP version: G950FXXU1CRAP Is CRAP!! LOL just kidding... | |
03-14-2018, 17:03 | #97 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | A520W finally unlocked! Quote:
BR | |
03-14-2018, 17:36 | #98 (permalink) |
Junior Member Join Date: Jan 2012
Member: 1710828 Status: Offline Sonork: callata Thanks Meter: 0 | hello friends of z3x, there is a problem with the last update, when it comes to repair imei everything ends well but when patching comes out correct but does not raise signal ... please correct that error ..... proven in three models, in j700m, g935f, g313ml, tube that download the version of the update and just patched well thanks ... |
03-15-2018, 03:32 | #104 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | GREAT update...!! z3x rock. may i know that s9+ sm-g965U t-mobile device unlock app supported for unlock by tmb server? waiting for reply |
03-15-2018, 15:41 | #105 (permalink) |
Crazy Poster Join Date: Apr 2008
Member: 739313 Status: Offline Thanks Meter: 12 | try to unlock normal first until read code from server and log says UNLOCK INSTRUCCIONES: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Unlock Selected model: SM-G570M Software version: 30.9 Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SM-G570M Android version: 6.0.1 Código del Producto: SM-G570MZKACOO Versión del telefono: G570MUBU2BRA3 PDA version: G570MUBU1API9 CSC version: Código de país CSC: Código de Venta CSC: HW version: Rev0.0 Phone SN: R28HB247J7H Chip name: EXYNOS7570 Módem: SHANNON305 Security patch: 2016-09-01 RF cal date: 20161116 IMEI: 353420083049588 Verificando derecho de Super Usuario... verdadero Reading NV data... Listo Checking NV data... Listo Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... error (0) Reading data... error Security damaged (4 23) Done with Samsung Tool PRO v.30.9 so how can repair security damaged its bin 2 can downgrade to bin 1 from some way i recieve this device on bin 2 with imei change imei cert its NG need to put original imei and dont cant find any way to do it can somebody help me thanks |
