02-03-2018, 05:05 | #107 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Yeah it's really not supposed to use up more credits if trying to re-unlock the same phone on the same IP. I don't think it should even check for IP, since checking for the same imei should be enough. If your IP happens to change within a few minutes then you get charged again, which suks (hate to misspell but this forum doesn't like sucking... ha-ha). | |
02-04-2018, 08:37 | #108 (permalink) | |
Freak Poster Join Date: Nov 2007
Member: 626321 Status: Offline Thanks Meter: 55 | Quote:
no change IMEI for seri G900 | |
02-04-2018, 10:31 | #109 (permalink) |
Freak Poster Join Date: Jan 2012 Location: south africa
Member: 1712315 Status: Offline Sonork: 100.1602299 Thanks Meter: 65 | Operation: Repair Selected model: SM-Z400Y Software version: 30.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting SDB device... OK Reading phone info... Model: Build: Tizen version: cat: standard output: Permission denied Incorrect model selected. This may damage your phone. Continue? Yes Checking Super user right... true HW version: cat: standard output: Permission denied Phone SN: cat: standard output: Permission denied Product code: cat: standard output: Permission denied Reading data from phone... error (1 Done with Samsung Tool PRO v.30.5 |
02-04-2018, 10:48 | #110 (permalink) | |
Freak Poster Join Date: Jul 2016
Member: 2596108 Status: Offline Thanks Meter: 58 | BillA is absolutely right, LISTEN TO CUSTOMERS BLANG Quote:
Fix this in your next update please, BillA makes a good suggestion. Make it based on IMEI so server doesn't calculate/charges the 2nd and or 3rd time. To be clear I am referring to T-Mobile unlock apps Qualcomm, G950U/G955U/N950U/G930T/G935T etc | |
The Following User Says Thank You to wirelessinfinit For This Useful Post: |
02-06-2018, 08:22 | #116 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | not worked even after root. s6 edge t-mobile Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 7.0 Product code: Phone version: G925TUVS6FRA3 PDA version: G925TUVS6FRA3 CSC version: G925TTMB6FRA3 CSC country code: USA CSC sales code: TMB HW version: Phone SN: R58G624A42K Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-01-01 RF cal date: IMEI: 350000000000006 Checking Super user right... true Reading NV data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.30.7 |
02-06-2018, 08:55 | #117 (permalink) | |
Member: 2596108 Status: Offline Thanks Meter: 58 | Quote:
02-06-2018, 10:19 | #118 (permalink) |
Insane Poster Join Date: Apr 2015 Location: tirur
Member: 2377319 Status: Offline Thanks Meter: 17 | hello helpme n7505 cert writing error BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N7505 Software version: 30.7 Checking CERT file... OK KEY ID: 0028 Waiting ADB device... OK Reading phone info... Model: SM-N7505 Android version: 5.1.1 Product code: Not Active Phone version: N7505XXUDOK5 PDA version: N7505XXUDPB1 CSC version: N7505OXEDPA1 CSC country code: Russia CSC sales code: SER HW version: REV__ Phone SN: Modem board: XMM7160 Security patch: 2016-02-01 RF cal date: Unknown IMEI: 004999010640000 Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... error (unknown) Done with Samsung Tool PRO v.30.7 |
02-06-2018, 12:56 | #119 (permalink) |
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | Samsung Tool 30.7 Update. Added over 160 function(s) to 21 model(s): GT-B3310I: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-C3011: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-C3200: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-C3200G: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-C3330: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-C3332: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-C3530: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-E2530: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-E2600: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-E2600M: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-E2652: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-E2652W: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-S3350: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-S3353: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-S3550: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW GT-S5229: + Write Firmware + Unlock + Read Unlock Codes + Reset User Lock + Repair IMEI + Repair SN + Repair BlueTooth + Repair HW SM-A810F: + Unlock + Read Unlock Codes + Repair IMEI + Patch Certificate + Read CERT + Write CERT SM-A810S: + Unlock + Read Unlock Codes + Repair IMEI + Patch Certificate + Read CERT + Write CERT SM-A810YZ: + Unlock + Read Unlock Codes + Repair IMEI + Patch Certificate + Read CERT + Write CERT SM-J250G: + Write Firmware + Unlock + Read Unlock Codes using credits + Read EFS + Write EFS + Read QCN + Write QCN + Read SEC + Write SEC SM-J250M: + Write Firmware + Unlock + Read Unlock Codes using credits + Read EFS + Write EFS + Read QCN + Write QCN + Read SEC + Write SEC Fixed bugs by your bug reports |
02-06-2018, 13:49 | #120 (permalink) |
Junior Member Join Date: Nov 2009 Location: pakistan lahore
Member: 1160288 Status: Offline Sonork: sooo Thanks Meter: 4 | Samsung Tool PRO 30.5 Update. New phones. First in the world. Reload this Page Reply very good update sir, please improved frp without combination file. |
