Old 02-03-2018, 00:31   #106 (permalink)
Member: 1949752
Thanks Meter: 8
No! It was a connection problem! I tried again immediately same laptop, same ip etc but took credits anyway!
Software was good!
Enviado desde mi iPhone utilizando Tapatalk
Old 02-03-2018, 05:05   #107 (permalink)
Member: 92260
Thanks Meter: 843
Software was good!
Yeah it's really not supposed to use up more credits if trying to re-unlock the same phone on the same IP. I don't think it should even check for IP, since checking for the same imei should be enough. If your IP happens to change within a few minutes then you get charged again, which suks (hate to misspell but this forum doesn't like sucking... ha-ha).
Old 02-04-2018, 08:37   #108 (permalink)
Member: 626321
Thanks Meter: 55
Unhappy
Originally Posted by blang View Post
Samsung Tool PRO 30.5
Added:
- support SM-J250G (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL, Direct READ codes via server, reboot download/recovery) - First in the world
- support SM-G611F (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes (no root, no server), Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-A530F (Flashing, Read/Write EFS, Unlock via MSL, Direct Read codes via server, reboot download/recovery) - First in the world
- support SM-A530N (Flashing, Read/Write EFS, Unlock via MSL, Direct Read codes via server, reboot download/recovery) - First in the world
- support SM-A530W (Flashing, Read/Write EFS, Unlock via MSL, Direct Read codes via server, reboot download/recovery) - First in the world
- support SM-A730F (Flashing, Read/Write EFS, Unlock via MSL, Direct Read codes via server, reboot download/recovery) - First in the world
Bug report - HERE
New phone adding request - HERE
Credits price and resellers - HERE
FACEBOOK NEWS - HERE
ATTENTION: DONT ALLOWED POST ANY LINK FOR ANY SOFTWARE.
hi sir
no change IMEI for seri G900
Old 02-04-2018, 10:31   #109 (permalink)
Member: 1712315
Sonork: 100.1602299
Thanks Meter: 65
Operation: Repair
Selected model: SM-Z400Y
Software version: 30.5
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Waiting SDB device... OK
Reading phone info...
Model:
Build:
Tizen version: cat: standard output: Permission denied
Incorrect model selected. This may damage your phone. Continue? Yes
Checking Super user right... true
HW version: cat: standard output: Permission denied
Phone SN: cat: standard output: Permission denied
Product code: cat: standard output: Permission denied
Reading data from phone... error (1
Done with Samsung Tool PRO v.30.5
Old 02-04-2018, 10:48   #110 (permalink)
Member: 2596108
Thanks Meter: 58
Exclamation BillA is absolutely right, LISTEN TO CUSTOMERS BLANG
You're absolutely right. I have said this before multiple times and the Product Manager, Blang, refuses to believe it and says it won't charge again on same IP, same IMEI, phone SN. Well it does still charge for every calculation it does and multiple people has said they lost credits it including myself.
Fix this in your next update please, BillA makes a good suggestion. Make it based on IMEI so server doesn't calculate/charges the 2nd and or 3rd time.
To be clear I am referring to T-Mobile unlock apps Qualcomm, G950U/G955U/N950U/G930T/G935T etc
The Following User Says Thank You to wirelessinfinit For This Useful Post:
Old 02-05-2018, 08:51   #111 (permalink)
Member: 626321
Thanks Meter: 55
Arrow
hi to all
why Z3X cannot backup cert for all new samsung ??
Old 02-05-2018, 15:08   #112 (permalink)
Member: 2443309
Thanks Meter: 14
need drect reset frp for modeles
Samsung SM-J250F
Samsung SM-J330F
Samsung SM-J730F
Samsung SM-J530F
...etc
Old 02-05-2018, 18:59   #113 (permalink)
Member: 2771799
pls add next time g570f imei repair
Old 02-06-2018, 04:06   #114 (permalink)
Member: 2808081
Sonork: phetry_qishash
Please
Link update z3x qualcome
Old 02-06-2018, 06:40   #115 (permalink)
Member: 2807070
Sonork: 550000
Thanks Meter: 37
thank you z3x always best
Old 02-06-2018, 08:22   #116 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
not worked even after root.
s6 edge t-mobile
Waiting ADB device... OK
Model: SM-G925T
Android version: 7.0
Product code:
Phone version: G925TUVS6FRA3
PDA version: G925TUVS6FRA3
CSC version: G925TTMB6FRA3
CSC country code: USA
CSC sales code: TMB
HW version:
Phone SN: R58G624A42K
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2018-01-01
RF cal date:
IMEI: 350000000000006
Reading NV data... OK
Checking NV data... error
Security damaged (1)
Done with Samsung Tool PRO v.30.7
Old 02-06-2018, 08:55   #117 (permalink)
Member: 2596108
Thanks Meter: 58
s6 edge t-mobile
Model: SM-G925T
Product code:
CSC sales code: TMB
HW version:
RF cal date:
Ghacks was able to unlock it on new bin. It's probably because of the busted imei you got there
Old 02-06-2018, 10:19   #118 (permalink)
Member: 2377319
Thanks Meter: 17
hello helpme
n7505 cert writing error
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore.
6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore.
7. Press 'Write NV DATA' if you need to restore NV backup.
Operation: Write CERT
Selected model: SM-N7505
Software version: 30.7
Checking CERT file... OK
KEY ID: 0028
Model: SM-N7505
Android version: 5.1.1
Product code: Not Active
Phone version: N7505XXUDOK5
PDA version: N7505XXUDPB1
CSC version: N7505OXEDPA1
CSC country code: Russia
CSC sales code: SER
HW version: REV__
Phone SN:
Modem board: XMM7160
Security patch: 2016-02-01
RF cal date: Unknown
IMEI: 004999010640000
Checking magic... OK
Running zTool, please wait... error (unknown)
Old 02-06-2018, 12:56   #119 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
Samsung Tool 30.7 Update.
Added over 160 function(s) to 21 model(s):
GT-B3310I:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-C3011:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-C3200:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-C3200G:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-C3330:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-C3332:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-C3530:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-E2530:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-E2600:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-E2600M:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-E2652:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-E2652W:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-S3350:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-S3353:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-S3550:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
GT-S5229:
+ Write Firmware
+ Unlock
+ Read Unlock Codes
+ Reset User Lock
+ Repair IMEI
+ Repair SN
+ Repair BlueTooth
+ Repair HW
SM-A810F:
+ Unlock
+ Read Unlock Codes
+ Repair IMEI
+ Patch Certificate
+ Read CERT
+ Write CERT
SM-A810S:
+ Unlock
+ Read Unlock Codes
+ Repair IMEI
+ Patch Certificate
+ Read CERT
+ Write CERT
SM-A810YZ:
+ Unlock
+ Read Unlock Codes
+ Repair IMEI
+ Patch Certificate
+ Read CERT
+ Write CERT
SM-J250G:
+ Write Firmware
+ Unlock
+ Read Unlock Codes using credits
+ Read EFS
+ Write EFS
+ Read QCN
+ Write QCN
+ Read SEC
+ Write SEC
SM-J250M:
+ Write Firmware
+ Unlock
+ Read EFS
+ Write EFS
+ Read QCN
+ Write QCN
+ Read SEC
+ Write SEC
Fixed bugs by your bug reports
Old 02-06-2018, 13:49   #120 (permalink)
Member: 1160288
Sonork: sooo
Thanks Meter: 4
Post Samsung Tool PRO 30.5 Update. New phones. First in the world. Reload this Page Reply
very good update sir,
please improved frp without combination file.
Page generated in 0.27316 seconds with 8 queries
