Old 04-15-2018, 21:47   #166 (permalink)
Member: 573393
Thanks Meter: 8
[ 04/16/2018 06:31:00 ق.ظ ] You have 40 credit(s) left. This operation takes 5 credits.Continue? Yes
[ 04/16/2018 06:31:00 ق.ظ ] Searching Samsung modem... یافت شد COM399
[ 04/16/2018 06:32:00 ق.ظ ] درحال خواندن اطلاعات گوشی...
[ 04/16/2018 06:32:00 ق.ظ ] مدل: SM-G955F
[ 04/16/2018 06:32:00 ق.ظ ] AP version: G955FXXU1AQK7
[ 04/16/2018 06:32:00 ق.ظ ] CSC version: G955FOVF1AQL1
[ 04/16/2018 06:32:00 ق.ظ ] CP version: G955FXXU1AQK7
[ 04/16/2018 06:32:00 ق.ظ ] کد دستگاه: VOD
[ 04/16/2018 06:32:00 ق.ظ ] Phone SN: R58J52PG5BL
[ 04/16/2018 06:32:00 ق.ظ ] IMEI: 358792085734747
[ 04/16/2018 06:32:00 ق.ظ ] شماره منحصر به فرد: CE0417140D52C01E0C
[ 04/16/2018 06:32:00 ق.ظ ] Searching Samsung diag port... یافت شد COM398
[ 04/16/2018 06:32:00 ق.ظ ] درحال خواندن اطلاعات گوشی... OK
[ 04/16/2018 06:32:00 ق.ظ ] CP build: Nov 20 2017 16:23:36
[ 04/16/2018 06:32:00 ق.ظ ] درحال خواندن دیتا از گوشی... OK
[ 04/16/2018 06:33:00 ق.ظ ] در حال محاسبه... OK
[ 04/16/2018 06:33:00 ق.ظ ] جستجوی سرور... OK
[ 04/16/2018 06:33:00 ق.ظ ] Waiting for server answer... OK
[ 04/16/2018 06:34:00 ق.ظ ] فریز کد: 74802938
[ 04/16/2018 06:34:00 ق.ظ ] NET lock: 19609173
[ 04/16/2018 06:34:00 ق.ظ ] SUB lock: 00000000
[ 04/16/2018 06:34:00 ق.ظ ] SP lock: 00000000
[ 04/16/2018 06:34:00 ق.ظ ] CP lock: 00000000
[ 04/16/2018 06:34:00 ق.ظ ] SIM lock: 00000000
[ 04/16/2018 06:34:00 ق.ظ ] For check lock status: *#7465625#
Old 04-16-2018, 03:00   #167 (permalink)
Member: 2827988
Sonork: Timgsm
Thanks Meter: 3
Mr. Blang
I have a question for you. Can you tell me SM-N950U U3 void 0x0 carrier T-Mobile is supported unlock by z3x with credits?
Thanks you.
Old 04-16-2018, 08:18   #168 (permalink)
Member: 2537939
Sonork: 100.1670350
Thanks Meter: 368
booooooom booom update
Old 04-16-2018, 08:57   #169 (permalink)
Crazy Poster
Member: 2814511
Thanks Meter: 39
samsung g532f unlock done by z3x.........
The Following User Says Thank You to gsmmim For This Useful Post:
Old 04-16-2018, 10:36   #170 (permalink)
Member: 2637339
Thanks Meter: 34
[ 4/15/2018 8:08:00 AM ] Checking hash file... OK
[ 4/15/2018 8:08:00 AM ] Searching Samsung modem... detected COM207
[ 4/15/2018 8:08:00 AM ] Reading phone info...
[ 4/15/2018 8:08:00 AM ] Model: SM-J120AZ
[ 4/15/2018 8:08:00 AM ] AP version: J120AZTUS2AQB2
[ 4/15/2018 8:08:00 AM ] CSC version: J120AZAIO2AQB2
[ 4/15/2018 8:08:00 AM ] CP version: J120AZTUS2AQB2
[ 4/15/2018 8:08:00 AM ] Product code: SM2J120AZKZAIO
[ 4/15/2018 8:08:00 AM ] Phone SN: R58HB21457A
[ 4/15/2018 8:08:00 AM ] IMEI: 356419075340846
[ 4/15/2018 8:08:00 AM ] Unique number: CFN00ACCFDA4D93
[ 4/15/2018 8:08:00 AM ] Searching Samsung diag port... detected COM206
[ 4/15/2018 8:08:00 AM ] Reading phone info... OK
[ 4/15/2018 8:08:00 AM ] CP build: Feb 13 2017 12:02:36
[ 4/15/2018 8:08:00 AM ] Reading data from phone... OK
[ 4/15/2018 8:08:00 AM ] Reading NV data... OK
[ 4/15/2018 8:09:00 AM ] Modem board: SHANNON308
[ 4/15/2018 8:09:00 AM ] Checking NV data... OK
[ 4/15/2018 8:09:00 AM ] Calculating... OK
[ 4/15/2018 8:09:00 AM ] Please wait, calculating codes... OK (time - 00:00:13)
[ 4/15/2018 8:09:00 AM ] Freeze code: 71706497
[ 4/15/2018 8:09:00 AM ] NET lock: 68614617
[ 4/15/2018 8:09:00 AM ] SUB lock: 00000000
[ 4/15/2018 8:09:00 AM ] SP lock: 00000000
[ 4/15/2018 8:09:00 AM ] CP lock: 00000000
[ 4/15/2018 8:09:00 AM ] SIM lock: 00000000
[ 4/15/2018 8:09:00 AM ] For check lock status: *#7465625#
Old 04-16-2018, 14:37   #171 (permalink)
amm_hazz's Avatar
Member: 235601
Thanks Meter: 62
Originally Posted by arunad View Post
Hi i.m using z3x 31.3 sc 02h unlock done but cant get call.i think need path certificate.but not aded this feathere ver.31.3
Im try
Update
Downgrade 6.0
Write castom rom
Re write efs qsn file
Wipe efs and re write
Same condition
Please it there any solution please
2. Scv37 unlock done(online code read )but now style invalid sim card.sim lock status update failed.
up........ need solution...
Old 04-18-2018, 03:37   #172 (permalink)
Alexandro Monte's Avatar
Member: 846805
Sonork: alex cavalcante
Thanks Meter: 259
Hi seemhor add G965F please via codes
The Following User Says Thank You to Alexandro Monte For This Useful Post:
Old 04-18-2018, 08:28   #173 (permalink)
Member: 99605
Thanks Meter: 56
where is frp unlock ? only usless core reading
The Following User Says Thank You to siudziu For This Useful Post:
Old 04-18-2018, 12:50   #174 (permalink)
gsm99's Avatar
Member: 104737
Thanks Meter: 69
Yes We Need It us soon us possible
The Following User Says Thank You to gsm99 For This Useful Post:
Old 04-18-2018, 20:19   #175 (permalink)
Member: 2620603
Thanks Meter: 2
Samsung Galaxy J3 Prime (Metro PCS) [SM-J327T1] can unlock via server?
Old 04-18-2018, 22:34   #176 (permalink)
Member: 2727207
Thanks Meter: 13
Yes you can............................................... .......................
Old 04-19-2018, 16:50   #177 (permalink)
Member: 784101
Sonork: 92737
Thanks Meter: 9
yes correct i got the same device today ATT(G965U_G965USQU1ARB7) same firmware version as your (also asking for network code) and when reading code with version 31.3 it hangs as well on Reading Data From Phone...and the device will reboot and say on the screen in read (SUBSYSTEM CRASHED MODEM!) with same more written in other colors
Old 04-19-2018, 22:26   #178 (permalink)
Member: 2727207
Thanks Meter: 13
1-install the latest drivers from samsung 1.5.65.0
2-dial *#0808# and select RMNET + DM + MODEM and press restart
3-enable usb debugging from developer options.
also try another cable and computer
good luck!!
Old 04-20-2018, 07:45   #179 (permalink)
Member: 784101
Sonork: 92737
Thanks Meter: 9
good luck!!
Thanks for advice,i have tried this but device still hangs on READING DATA FROM PHONE...And here is pic of what it says on the screen.
And here is log_
Checking Login and Password... OK
Ballance: 25 crd.
You have 25 credit(s) left. This operation takes 10 credits.Continue? Yes
Waiting ADB device... OK
Model: SM-G965U
Android version: 8.0.0
PDA version: G965USQU1ARB7
CSC version: G965UOYN1ARB7
Phone version: G965USQU1ARB7
Product code: SM-G965UZBAATT
CSC country code: USA
CSC sales code: ATT
Phone SN: R38K20A8BYN
IMEI: 354641090______
HW version: REV1.1
RF cal date: 2018.02.22
Chip name: SDM845
Modem board: SDM845
Security patch: 2018-02-01
Boot Warranty bit: 0
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Old 04-20-2018, 12:10   #180 (permalink)
Member: 784101
Sonork: 92737
Thanks Meter: 9
ok it finally got it to work on WIN7 32BIT
1.install fresh installation of version 31.3
2.activate switch to better version
3.2-dial *#0808# and select RMNET + DM + MODEM and press restart
4.Do read code and no more hanging.
Page generated in 0.37295 seconds with 8 queries
