Old 07-11-2018, 07:43   #91 (permalink)
Member: 1889964
full control on z3x account with credits. so we don't lose credits.
Old 07-16-2018, 02:05   #92 (permalink)
Member: 2772795
Thanks Meter: 5
it shows me Programm Damaged
Old 07-17-2018, 19:47   #93 (permalink)
Member: 1062231
Thanks Meter: 30
PLYZE M BLANG ADAIN
SAMSUNG
FRP RESET UART Method ALL MODELLE 2017+2018
Old 07-20-2018, 18:25   #94 (permalink)
Member: 2722746
Hello link to download the latest setup
Old 07-26-2018, 20:02   #95 (permalink)
Member: 1236922
Sonork: sajer007
Thanks Meter: 101
please add J810G unlock option
Old 07-27-2018, 07:19   #96 (permalink)
Member: 1817738
Thanks Meter: 27
sir i have SCV35.... today i read network unlock code via server then code read success full.... but that phone not asking network lock unlock screen please help me sir thanks.....
Old 07-27-2018, 07:27   #97 (permalink)
Member: 1556436
Thanks Meter: 66
Au versions of galaxies doesn't ask for unlock code, generating unlock codes via server is just wasting ur credits but all these services that uses server to generate codes keep adding Japan Au galaxy variants, i really don't know why, looks like scam, just flash combination file with unaccepted sim if ask for code put 00000000 then flash the docomo variant software on it, in this case of SCV35 flash Sc-03J firmware on the scv35 after putting code with combination file.
Sent from my iPhone using Tapatalk
The Following User Says Thank You to samuelsteve For This Useful Post:
Old 08-07-2018, 20:56   #98 (permalink)
Member: 2703007
Thanks Meter: 8
I know you said no more cert patch for new models but what about the Galaxy S7 ?? on firmware 8.0 Oreo ? Please just update that for me I dont need any other phones just S7 please , the G930F I will be very grateful
Old 08-09-2018, 18:10   #99 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
not supported s8 sm-g950u new firmware for t-mobile app unlock
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will appear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Unlocking using Server:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information'
to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings)
Reading codes using sever:
5. Press 'Read Codes via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Unlock
Selected model: SM-G950U
Software version: 33.5
Checking Login and Password... OK
Ballance: 158 crd.
You have 158 credit(s) left. This operation takes 10 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-G950U
Android version: 8.0.0
PDA version: G950USQS5CRF5
CSC version: G950UOYN5CRF5
Phone version: G950USQS5CRF5
Product code: SM-G950UZKATMB
CSC country code: USA
CSC sales code: TMB
Phone SN: R28J41VZXYJ
IMEI: 355987081755497
HW version: REV1.0
RF cal date: 2017.04.15
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2018-07-01
Boot Warranty bit: 0
Searching Samsung diag port... not found
Rebooting phone... OK
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Rebooting to upload... OK
Searching Ramdump interface... COM8 detected
Calculating... error (0)
Done with Samsung Tool PRO v.33.5
Old 08-09-2018, 18:11   #100 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
Operation: Unlock
Ballance: 158 crd.
Model: SM-G950U
CSC sales code: TMB
HW version: REV1.0
Chip name: MSM8998
Searching Samsung diag port... detected COM5
Reading phone info... OK
Reading data from phone... error (0), skip
Start... OK
Old 08-09-2018, 18:11   #101 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
Operation: Unlock
Ballance: 158 crd.
Model: SM-G950U
CSC sales code: TMB
HW version: REV1.0
Chip name: MSM8998
Start... OK
Old 08-13-2018, 10:28   #102 (permalink)
dark_boy99's Avatar
Member: 2425283
Thanks Meter: 95
stopped working sams_reloded after update
any sol team?
Old 08-13-2018, 15:48   #103 (permalink)
Member: 919662
Hi, every one
I am not that professional , some times I just log in to read about the phones and technical issues.
I appreciate all your work what you do for the others to resolve the problems
thanks again.
Old 08-23-2018, 06:20   #104 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
new firmware not supported.
Hello, Z3X team, please help.
ENABLE USB DEBUGING
SELECT MTP+ADB, PRESS OK
ITS FAIELD.
Operation: Unlock
Selected model: SM-G955U
Ballance: 43 crd.
You have 43 credit(s) left. This operation takes 10 credits.Continue? Yes
Model: SM-G955U
PDA version: G955USQU5CRG3
CSC version: G955UOYN5CRG3
Phone version: G955USQU5CRG3
Product code: SM-G955UZKATMB
CSC sales code: TMB
Phone SN: R28J71749VM
IMEI: 355980083333553
HW version: REV1.0
RF cal date: 2017.07.12
Chip name: MSM8998
Start... OK
Searching Ramdump interface... COM5 detected
ENABLE USB DEBUIGNG
SELECT RMNET+DM+MODEM, ITS FAILED
Operation: Unlock
Ballance: 43 crd.
Model: SM-G955U
CSC sales code: TMB
HW version: REV1.0
Chip name: MSM8998
Searching Samsung diag port... detected COM6
Start... OK
Old 08-23-2018, 13:43   #105 (permalink)
Member: 2335578
Thanks Meter: 105
Flash combo modem
ENABLE USB DEBUGING
ITS FAIELD.
Operation: Unlock
Ballance: 43 crd.
Model: SM-G955U
CSC sales code: TMB
HW version: REV1.0
Chip name: MSM8998
Start... OK
ENABLE USB DEBUIGNG
Operation: Unlock
Ballance: 43 crd.
Model: SM-G955U
CSC sales code: TMB
HW version: REV1.0
Chip name: MSM8998
Start... OK
Sent from my Pixel 2 XL using Tapatalk
Page generated in 0.26468 seconds with 9 queries
