07-27-2018, 07:19 | #96 (permalink) |
Freak Poster Join Date: Sep 2012
Member: 1817738 Status: Offline Thanks Meter: 27 | sir i have SCV35.... today i read network unlock code via server then code read success full.... but that phone not asking network lock unlock screen please help me sir thanks..... |
07-27-2018, 07:27 | #97 (permalink) | |
Freak Poster Join Date: Apr 2011
Member: 1556436 Status: Offline Thanks Meter: 66 | Quote:
Au versions of galaxies doesn't ask for unlock code, generating unlock codes via server is just wasting ur credits but all these services that uses server to generate codes keep adding Japan Au galaxy variants, i really don't know why, looks like scam, just flash combination file with unaccepted sim if ask for code put 00000000 then flash the docomo variant software on it, in this case of SCV35 flash Sc-03J firmware on the scv35 after putting code with combination file. Sent from my iPhone using Tapatalk | |
The Following User Says Thank You to samuelsteve For This Useful Post: |
08-07-2018, 20:56 | #98 (permalink) |
Major Poster Join Date: Apr 2017
Member: 2703007 Status: Offline Thanks Meter: 8 | I know you said no more cert patch for new models but what about the Galaxy S7 ?? on firmware 8.0 Oreo ? Please just update that for me I dont need any other phones just S7 please , the G930F I will be very grateful |
08-09-2018, 18:10 | #99 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | not supported s8 sm-g950u new firmware for t-mobile app unlock -- UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G950U Software version: 33.5 Checking Login and Password... OK Ballance: 158 crd. You have 158 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 8.0.0 PDA version: G950USQS5CRF5 CSC version: G950UOYN5CRF5 Phone version: G950USQS5CRF5 Product code: SM-G950UZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R28J41VZXYJ IMEI: 355987081755497 HW version: REV1.0 RF cal date: 2017.04.15 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-07-01 Boot Warranty bit: 0 Searching Samsung diag port... not found Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM8 detected Reading data from phone... OK Calculating... error (0) Done with Samsung Tool PRO v.33.5 |
08-09-2018, 18:11 | #100 (permalink) |
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G950U Software version: 33.5 Checking Login and Password... OK Ballance: 158 crd. You have 158 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 8.0.0 PDA version: G950USQS5CRF5 CSC version: G950UOYN5CRF5 Phone version: G950USQS5CRF5 Product code: SM-G950UZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R28J41VZXYJ IMEI: 355987081755497 HW version: REV1.0 RF cal date: 2017.04.15 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-07-01 Boot Warranty bit: 0 Searching Samsung diag port... detected COM5 Reading phone info... OK Reading data from phone... error (0), skip Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM8 detected Reading data from phone... OK Calculating... error (0) Done with Samsung Tool PRO v.33.5 |
08-09-2018, 18:11 | #101 (permalink) |
08-13-2018, 15:48 | #103 (permalink) |
Junior Member Join Date: Dec 2008
Member: 919662 Status: Offline Thanks Meter: 0 | Hi, every one I am not that professional , some times I just log in to read about the phones and technical issues. I appreciate all your work what you do for the others to resolve the problems thanks again. |
08-23-2018, 06:20 | #104 (permalink) |
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | new firmware not supported. Hello, Z3X team, please help. ENABLE USB DEBUGING SELECT MTP+ADB, PRESS OK ITS FAIELD. Operation: Unlock Selected model: SM-G955U Software version: 33.5 Checking Login and Password... OK Ballance: 43 crd. You have 43 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G955U Android version: 8.0.0 PDA version: G955USQU5CRG3 CSC version: G955UOYN5CRG3 Phone version: G955USQU5CRG3 Product code: SM-G955UZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R28J71749VM IMEI: 355980083333553 HW version: REV1.0 RF cal date: 2017.07.12 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-07-01 Boot Warranty bit: 0 Searching Samsung diag port... not found Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM5 detected Reading data from phone... OK Calculating... error (0) Done with Samsung Tool PRO v.33.5 ENABLE USB DEBUIGNG SELECT RMNET+DM+MODEM, ITS FAILED Operation: Unlock Selected model: SM-G955U Software version: 33.5 Checking Login and Password... OK Ballance: 43 crd. You have 43 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G955U Android version: 8.0.0 PDA version: G955USQU5CRG3 CSC version: G955UOYN5CRG3 Phone version: G955USQU5CRG3 Product code: SM-G955UZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R28J71749VM IMEI: 355980083333553 HW version: REV1.0 RF cal date: 2017.07.12 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-07-01 Boot Warranty bit: 0 Searching Samsung diag port... detected COM6 Reading phone info... OK Reading data from phone... error (0), skip Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM5 detected Reading data from phone... OK Calculating... error (0) Done with Samsung Tool PRO v.33.5 |
08-23-2018, 13:43 | #105 (permalink) | |
No Life Poster Join Date: Jan 2015
Member: 2335578 Status: Offline Thanks Meter: 105 | Flash combo modem Quote:
