10-24-2017, 13:16 | #1 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Saudi Arbia
Member: 2080403 Status: Offline Sonork: 100.1645596 Thanks Meter: 52 | samsung tool pro activation on easy jtag box FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G530H Software version: 29.5 File analysis... OK Total file size: 0x475C0C74 (1141 Mb) Searching USB Flash interface... COM15 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending hyp.mbn... OK Sending NON-HLOS.bin... OK Sending sec.dat... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending persist.img.ext4... OK Sending persdata.img.ext4... OK Sending modem.bin... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Flashing done (time - 00:02:54) Done with Samsung Tool PRO v.29.5 boom boom zte team box jtag butt finally m got samsun tool pro activation |
