Old 09-03-2019, 10:21   #61 (permalink)
Member: 2135878
Thanks Meter: 6
my box working in shell good , samsung tool working good but samsung tool pro "programme damaged" error show.......... what is the problem and how can i solve it
Old 09-30-2019, 15:02   #62 (permalink)
Member: 2069141
Thanks Meter: 3
Same here with my box
Sent from my Nokia 5.1 Plus using Tapatalk
Old 09-30-2019, 15:41   #63 (permalink)
Member: 719708
Reply With Quote Multi-Quote This Message Quick reply to this message Thanks Meter
Old 09-28-19, 13:32 #1745 (permalink)
*****box
Member: 719708
i bought a replacement sim card for my z3x box but i found that the old ones not activate in the new sim card
serial number of sim sim card AADD022E
serial number of new sim card AAA08FD5
Old 11-13-2019, 11:12   #64 (permalink)
Member: 2587647
Thanks Meter: 7
the best way is this:
1. first connect another dongle to your pc
2. go to shell select "hardware wizard" then you can see "reapir dead card" selected
3. click on Next now see "alcer micro card ...."
4. at this time eject dongle smart card and put Z3X smart card
note: don't eject dongle entirely only only smart card
5. after that click on Next button
6. you can see firmware upgraded
7. done
Programm damaged solved
wink
Old 11-13-2019, 13:50   #65 (permalink)
Member: 1890442
Sonork: 100.1621735
Thanks Meter: 39
Z3X Programm Damaged Do u solve this pls explain the process
Old 11-13-2019, 13:52   #66 (permalink)
Member: 1890442
Sonork: 100.1621735
Thanks Meter: 39
Z3X Programm Damaged how Do u solve this pls explain the process
Old 11-13-2019, 13:53   #67 (permalink)
Member: 1890442
Sonork: 100.1621735
Thanks Meter: 39
Originally Posted by ..::KASHIF::.. View Post
Z3X Programm Damaged Done now Working
Old 11-13-2019, 14:13   #68 (permalink)
Member: 1890442
Sonork: 100.1621735
Thanks Meter: 39
Originally Posted by Nguemtel View Post
ok thank i finaly resole my problem with repair on z3x shell...
tell me the process or give screen shots
Old 11-13-2019, 14:16   #69 (permalink)
Member: 1890442
Sonork: 100.1621735
Thanks Meter: 39
Old 11-29-2019, 17:28   #70 (permalink)
Member: 2520116
Thanks Meter: 9
Z3x Program Damaged solution
The easy way to fix Z3x program damaged
Watch this video and follow the instructions step by step
100% working and tested by Learn & Share Team
Old 12-10-2019, 13:14   #71 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 788
Originally Posted by blang View Post
If you have problem - Program Damaged while running software.
1. Try clean SMARTCARD pins. Try use other reader for SMARTCARD. Try reinstall drivers. Try use other PC.
same problem then.
2. Disconnect all other boxes, dongles and try use function repair dead card:
- If function not allowed, remove smart card before goto window with repair dead card function
- then after сhoice repair, immediately put card back and do repair.
same problem then.
3. If BOX under warranty - ask reseller for replace.
4. If BOX not under warranty, and last time box using was not more than 6month, and you have damaged card in hands - buy empty card and we will replace activation to new card.
Just send email with SN old and new card: sales @z3x-team.com
is there any way to get dead card serial number by login information?
Old 12-10-2019, 13:29   #72 (permalink)
Member: 2613252
Thanks Meter: 1,837
to obtain information on the old serial number of the old smart card damaged behind the box there is a label applied with a bar code to the usb port of the z3x box.
if you don't have a label still applied behind the z3x box watch this video that you wrote in the previous post tarkusius
https://www.youtube.com/watch?v=-emsgpf23Ec
Old 02-15-2020, 14:14   #73 (permalink)
Member: 1024132
Thanks Meter: 34
hello
please active my new sim card withe new sn
OLD SN//0003056F
NEW SN//AA090BA5
THANKS FOR ADVANCE
NB:i have sende you mail and i have comfirmed wihe screm shot
Old 09-19-2020, 16:32   #74 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 850
me solution
open shell
click in setting
now wiew the option of repair card damaged
click in next
now connect la dongle with la card
next to all
wait repair card
full of card of new.
Old 12-11-2020, 08:55   #75 (permalink)
Member: 1920581
Sonork: 100.1674372
Thanks Meter: 45
Repair card option disable in shell how to fix.
Page generated in 0.40368 seconds with 8 queries
