08-13-2018, 07:07 | #1 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Heart of Asia
Member: 1706168 Status: Offline Sonork: 100.1619095 Thanks Meter: 66 | Samsung Tool pro program damaged [Instruction step by step] |
08-14-2018, 07:58 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | Quote:
1. Try clean SMARTCARD pins. Try use other reader for SMARTCARD. Try reinstall drivers. Try use other PC. same problem then. 2. Disconnect all other boxes, dongles and try use function repair dead card: - If function not allowed, remove smart card before goto window with repair dead card function - then after сhoice repair, immediately put card back and do repair. same problem then. 3. If BOX under warranty - ask reseller for replace. 4. If BOX not under warranty, and last time box using was not more than 6month, and you have damaged card in hands - buy empty card and we will replace activation to new card. Just send email with SN old and new card: sales @z3x-team.com | |
The Following 16 Users Say Thank You to blang For This Useful Post: |
08-15-2018, 01:43 | #3 (permalink) |
Freak Poster Join Date: Sep 2011 Location: El Salvador
Member: 1655844 Status: Offline Thanks Meter: 25 | z3x programmed damaged! Hi! i buy it Z3X full activated but 2 days later gave me this error "programmed damaged" when try it to fix whith shell not able to fix this, always show new shell available but not download anything, i downloaded latest shell from your website but show same error again and again, im very frustrated but 2 days later box is screwed and able to use again... thanks i need fix this |
08-31-2018, 11:41 | #4 (permalink) |
Freak Poster Join Date: Oct 2005 Location: lagos nigeria
Member: 192296 Status: Offline Sonork: 100.1623059 Thanks Meter: 24 | Program damaged Gooday all of a sudden my z3x shows program damaged I've reinstalled software formatted pcs done everything possible still no success don't know if you can shift activation to other dongle coz I have another dongle not activated on Samsung pro and my present dongle has all activation pro, LG and some z3$ credit Sent from my M6 using Tapatalk |
09-11-2018, 19:49 | #7 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Sir need ur help,, I erroneously activated LG instead of Samsung Pro Activation now I need help in this regard to solve the issue customer is getting angry. Box Seriel number is AADA7EC6. Thanx n BR |
09-28-2018, 16:41 | #11 (permalink) |
Freak Poster Join Date: Jul 2008 Location: PK
Member: 805129 Status: Offline Thanks Meter: 191 | Samsung Tool Pro Program Damaged What's the Problem With z3x Hello z3x team, I have a problem in a long time card remove with z3x box Now two days ago a new problem start with my z3x Program damaged I have install new windows also change laptop to desktop pc CARD change to another empty box but problem still same Program damaged or Samsung toolpro suddenly close when software try to open. Z3x shell show info ok also old setup 19.x open ok Mr.Blang please help me I'm worry about it |
10-10-2018, 06:49 | #12 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1828619 Status: Offline Thanks Meter: 0 | Hello Z3x Team, pls I have this issue with my box I just activated it to pro 3 months ago but when ever I opened the pro I just see the ”Programme Damaged” I have try all what should be try to get it work but I still can’t makre it work either pls do I need to buy another box and give you the serial no so as to transfer the pro activation on it pls I don’t want to loose woefully. Thanks in advance. |
10-21-2018, 18:10 | #15 (permalink) |
Junior Member Join Date: Sep 2017 Location: Iran , Shiraz Paradis
Member: 2754180 Status: Offline Thanks Meter: 0 | Z3x programm damaged Hello z3x team, I have a problem in a long time card remove with z3x box Now two days ago a new problem start with my z3x Program damaged I have install new windows also change laptop to desktop pc CARD change to another empty box but problem still same Program damaged or Samsung toolpro suddenly close when software try to open. Z3x shell show info ok also old setup 19.x open ok |
