03-08-2013, 13:20 | #79 (permalink) |
No Life Poster Join Date: Oct 2011 Location: worldwide
Member: 1677015 Status: Offline Thanks Meter: 53 | Selected model: S3570 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Phone detected Switch phone in TAT mode... OK Reading phone info... OK Phone version: S3570BVLI4 CSC version: S3570FTMLI2 IMEI: 35333905159733 Phone SN: RV1CA50Y60 Phone BT: 004:2B:E49:FC Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.14.1 Done with Samsung Tool v.14.1 Great job.Thanks |
03-08-2013, 13:35 | #81 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Asia
Member: 1286135 Status: Offline Thanks Meter: 221 | After flashed now phone is blinking GT-S3570 SAMSUNG Problem phone locked only LOGS: Selected model: S3570 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Reconnect battery and connect phone to USB cable Phone detected Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading OTP register... OK OTP register: 473E8100 Reading product ID... OK Product ID: 0002894118DA7300 Reading SCROM version... OK SCROM version: 0x31 Chipset version: 0x48 Sending loader... OK Start loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Loading flash info... OK Configure Flash... OK Erase memory for external loader... OK Sending external loader... OK Start external loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Load flash info... OK Configure Flash... OK OK Loading PTT file... OK Reading first block... OK Erasing first block... OK Flashing first block... OK Init bad block... OK Erasing IMAGE... OK Erasing LCDACT... OK Erasing DATA_RW... OK Erasing DSP... OK Erasing PAGE... OK Erasing MAIN... OK Erasing a... OK Erasing b... OK Erasing c... OK Erasing d... OK Erasing OTPW... OK Writing IMAGE... OK Writing LCDACT... OK Writing DATA_RW... OK Writing DSP... OK Writing PAGE... OK Writing MAIN... OK Writing a... error Done with Samsung Tool v.14.1 Selected model: S3570 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Reconnect battery and connect phone to USB cable Phone detected Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading OTP register... OK OTP register: 473E8100 Reading product ID... OK Product ID: 0002894118DA7300 Reading SCROM version... OK SCROM version: 0x31 Chipset version: 0x48 Sending loader... OK Start loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Loading flash info... OK Configure Flash... OK Erase memory for external loader... OK Sending external loader... OK Start external loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Load flash info... OK Configure Flash... OK OK Loading PTT file... OK Reading first block... OK Erasing first block... OK Flashing first block... OK Init bad block... OK Erasing IMAGE... OK Erasing LCDACT... OK Erasing DATA_RW... OK Erasing DSP... OK Erasing PAGE... OK Erasing MAIN... OK Erasing a... OK Erasing b... OK Erasing c... OK Erasing d... OK Erasing OTPW... OK Writing IMAGE... OK Writing LCDACT... OK Writing DATA_RW... OK Writing DSP... OK Writing PAGE... OK Writing MAIN... OK Writing a... error Done with Samsung Tool v.14.1 What should i do Z3X Team... |
03-08-2013, 15:01 | #85 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Thanks Mr.Blang You Are Great Working I Hope Next Update Add I9300 100% Working IMEI Repair Solution & I9500 Unlock Support Thanks Again. BR. Arsalan gsm2000. |
