05-16-2013, 12:19 | #46 (permalink) |
Freak Poster Join Date: Feb 2006 Location: UK Age: 44
Member: 232341 Status: Offline Thanks Meter: 55 | tested rj45 c3300k Phone must be powered on. 2. Type *#7284# and choose Modem. 3. Type *#9090# and DM OVER UART. Selected model: I9305 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Searching server... OK NET lock: #7465625*638*75137369# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.14.4 |
05-16-2013, 15:37 | #47 (permalink) |
Freak Poster Join Date: May 2008 Location: Kerala.Malappuram
Member: 775335 Status: Offline Sonork: 100.1616277 Thanks Meter: 22 | Selected model: I9300 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 File analysis... Exception: Access violation at address 004032C5 in module 'SamsungTool.exe'. Read of address 00000000 why this error? |
06-21-2013, 16:14 | #50 (permalink) |
Banned Join Date: May 2013
Member: 1950464 Status: Offline Thanks Meter: 0 | Still waiting for answer!!! YOUR INSTRUCTIONS FOR IMEI REPAIR AND MANY OTHER OPTIONS FOR THE M919 ARE WRONG AND MAKE NO SENSE... HERE IS YOUR INSTRUCTIONS FOR MICRO USB micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for both options. 3. Type *#9090# and choose USB Diag. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Repair" button. 8. In opened window fill fields what you need to repair. 9. Press "OK". FIRST OF ALL WHEN YOU GO INTO PHONE UTILITY MENU (*#7284#) THERE IS NOT 2 OPTIONS TO SELECT MODEM ONLY ONE UNDER UART THE USB IS NOT THERE. SECONDLY, WHEN YOU ENTER SERVICE MODE (*#9090#) THERE IS NO USB DIAG OPTION. WHAT PHONES ARE YOU GETTING THESE INSTRUCTIONS FROM. I HAVE 3 M919'S IN HAND AND THESE INSTRUCTIONS MAKE NO SENSE. WHY DONT YOU MAKE SURE THESE OPTIONS EXIST BEFORE YOU MAKE INSTRUCTIONS. THIS IS HORRIBLE. AND DO NOT TELL ME TO USE UART CABLE. IT SAYS YOU CAN USE USB CABLE AND I WANT TO USE USB CABLE. SO COULD YOU PLEASE GIVE ME THE RIGHT INSTRUCTIONS FOR THE USB. THANKS! |
12-06-2013, 00:06 | #51 (permalink) |
Junior Member Join Date: Jan 2006
Member: 215816 Status: Offline Thanks Meter: 0 | Friend I have also faced problem with Samsung M919 Build: M9615A-CEFWTAZM-4.0.17122 denied access and the suggested instructions here, but I think the right not only for this build M9615A-CEFWTAZM-4.0.17122 because they were successful unlock M919 were build CEFWTAZM-4.0.17062, usb cable to use with M9615A-CEFWTAZM-4.0.17122 must enter * # 0808 # and select AP and below DM + modem + ADB and select ok. Now I wonder if I upgrade to a lower version than 4.3 buid tmb changes? which version of android M919 that worked? |
