02-07-2013, 20:02 | #1 (permalink) |
Crazy Poster Join Date: Jan 2005 Age: 39
Member: 108544 Status: Offline Thanks Meter: 4 | samsung unlock problem i want to unlock z170 via qualcomm mode, the drivers are installed correctly but the samsung tool in port settings doesn't show the port on which it is installed. it happens with all the models that i wan't to unlock via usb. i have uninstalled the shell and samsung tool but the problem remains. thanks in advance for your help. |
02-08-2013, 06:13 | #2 (permalink) |
No Life Poster Join Date: Dec 2007 Location: egypt
Member: 648590 Status: Offline Thanks Meter: 267 | Samsung mode method (2in1 cable): 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Samsung mode 3. Connect 2in1 cable, setup drivers. 4. select port of RJ45 connector in port settings 5. select Read codes or direct. 6. Press sp Unlock |
02-12-2013, 15:49 | #3 (permalink) |
Member: 108544 Status: Offline Thanks Meter: 4 | i think you didnt understand me. i cant unlock any phone(qualcomm mode) that can only be unlocked by usb, because in port settings not appear the port where it is installed. |
