01-07-2011, 13:39 | #6 (permalink) |
Major Poster Join Date: Oct 2008
Member: 886441 Status: Offline Sonork: 989090 Thanks Meter: 4 | Samsung Secret Codes ! PROGRAMMER CODES! *#06# displays phones IMEI NO. *#9999# SW Version. *#8888# HW Version. *#0842# Vibrator. *#0289# Buzzer. *#0228# Battery Stat. *#0782# RTC Display (?¿) *#0523# LCD Contrast. *#0377# NVM error log (?¿) *#5646# GSM Logo Set. *#0778# Sim Serv, Table. (?¿) *#0638# SIM Network ID. *#0746# SIM info. *#0076# Production No. *#3323# Forced Crash (?¿ don't know, but dose not sound good) *#2576# SIM error. *#4357# This screen ( the actural help screen) *#9324# Netmon <> press the hung up key to exit. *#0778# To see what your SIM suportes. *#0746# Your sim type. *#32439483 Digital Audio Interference off. *#32436837# Digital Audio Interference on. *#9998*JAVA# Edit GPRS/CSD settings (S100 only). *#9998*Help# Screen / List of codes. *#9998*RTC# RTC Display. *#9998*bat# Battery Status. *#9998*buz# Turns Buzzer On. *#9998*vub# Turns Vibator On. *#9998*LCD# LCD Contrast. *#9998*9999# Sotfware Version. *#9998*8888# Hardware Version. *#9998*377# Non Volatile Merory Error Log. *#9998*NET# SIM NEtwork ID *#9998*778# SIM Serv. Table. *#9998*968# Remider Tune. *#9998*NVM# Displays Non-Volitile Mermory Status. *#9999*C# Netmon. *#9998*2576# Forces SIM Error. *#9998*DEAD# Forces Phone Crash. *#9998*533# (LED). *#999* Show date and alarm clock. *#8999*638# show network information. *#9998*5646# change operator logoat startup. *#9998*968# View melody alarm. *2767*MEDIA# Resets the media on phone <>DELETES all downloaded PICS/TONES <> *2767*FULL# Resets the EEPRON* <>°DANGEROUS°<> *2767*CUST# Resets the sustom EEPRON. *2767*JAVA# Resets JAV downloads ( dealets all downloaded midits) *2767*STACKREST# RESETS STACK. *2767*225RESET# * VERY Dangerous. #0111*0000000# Removes SIM Lock. *2767*66335# *2767*3700# *2767*7100# *2767*8200# *2767*7300# *2767*2877368# *2767*33927# *2767*85927# *2767*48927# *2767*37927# *2767*28927# *2767*65927# *2767*29927# *2767*78927# *2767*79928# *2767*79928# *2767*82927# *2767*787927# *2767*73738927# *2767*33667# *2767*85667# *2767*688# = Unlocking code *#8999*8378# = All in one code *#4777*8665# = GPSR Tool *#8999*3825583# = External Display *#8999*377# = Errors *#2255# = call list #*5737425# = JAVA Something chouse 2and it chrashed. #*536961# = Java Status Code #*536962# = Java Status Code #*536963# = Java Status Code #*53696# = Java Status Code #*1200# = AFC DAC Val #*1300# =IMEI #*1400# = IMSl #*2562# ?¿ white for 15 sec than restarts. #*2565# Check Blocking #*3353# check code #*3837# = ?¿ White for 15 secs than restarts. #*3849# = ?¿ white for 15 secs than restarts. #*7222# = Operation Typ ( class C GSM) #*7224# = I got ERROR ! #*7252# = Operation Typ ( Class B GPRS) #*7271# Multi Slot ( Class 1 GPRS) #*7271# Multi Slot ( Class 4 GPRS) #*7337# = EEPROM Reset ( unlock and resets Wap settings) #*2787# CRTP ON/OFF #*3737# L1 Dbg Data #*5133# L1 Dbg Data #*7288# GPRS Attached #*7287# GPRS Detached #*7666# SrCell Data #*7693# Sleep Act/Deact ( enable or disable the black screen after doing nothen for a while) #*7284# Class B/C Or GPRS #*2256# Calibration Info #*2286# Battery Data #*2679# Copycat Feature (Activate or deactavite) #*3940# External loop 9600 bps #*8462# sleeptime #*5176# L1 Sleep #*5187# L1C2G Trace ( activate or deactivate) #*3877# Dump Of spy trace 5/31/2006 12:15 PM *#8999*636# Have no clue i see 20 lines *#8999*8376263# HW Ver SW Ver and build date *#746565# Checks the locks *7465625*638*Code# Enables Network lock #7465625*638*Code# Disables Network lock #7465625*782*code# Disables Subset lock *7465625*782*code# Enables subset lock *7465625*746*code# Enables SIM lock #7465625*746*code# disables SIM lock *7465625*28746# Auto SIM lock On #7465625*28746# Auto SIM lock Off (*Known Unlock CODES*) S500/ P400/ E500/ E700/ X100/ X600/ E100/ Enter *2767*3855# with and accepted SIM card If this codes fails, Enter *2767*688# or #* 7337# A300/ A400 / A800 *2767*637# Enter code above with an accepted SIM card. S100 / S300 / V200 / V205 / E710 / E715 / D410 / X426/ *2767*7822573738# Enter code above with an accepted SIM card. If the code above fails) 1.) Insert a SIM card which the phone dose not accept. 2.)If you see wrong Card, type #9998*3323# 3.)Press exit and select number 7. Phone will reboot. 4.) Now SIM should work. 5.) Type *0141# and then press call. 6.) Power off the phone and inser anther SIM card. 7.) If a code is requested, enter 00000000. |
01-14-2011, 13:19 | #7 (permalink) |
Major Poster Join Date: Jul 2010
Member: 1353340 Status: Offline Sonork: none Thanks Meter: 4 | Try this site Pro Unlocking.com- Unlock Your Phone to get the unlock code to unlock your mobile and also get the unlock instruction in the same site..... |
04-11-2011, 12:06 | #9 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Quote:
read code OR flash with : SamsungPST_W259 For India 1.0.002 | |
The Following User Says Thank You to omkarvitekar For This Useful Post: |
04-12-2011, 13:06 | #10 (permalink) |
Junior Member Join Date: Apr 2009 Location: Lucknow
Member: 1011844 Status: Offline Sonork: 0786 Thanks Meter: 1 | I did flash by pst bt its only gsm flashing when i did try for cdma by download mode (to use 9 plus on/off) but after few second its not responding its show only one error flashing data failed what i do now help plzzzzzzzzzzzzzzzzz any one is master for Samsung |
04-12-2011, 13:30 | #11 (permalink) | |
cdma flash with usb 100% working & tested solu. guide ::SCH-W259(M-Duo)_PST_DownloadGuide.rar Last edited by omkarvitekar; 04-12-2011 at 13:40. | |
04-14-2011, 07:36 | #12 (permalink) |
Freak Poster Join Date: May 2007 Location: PATTAMUNDAI
Member: 508774 Status: Offline Sonork: 100.1590207 Thanks Meter: 207 | check this sir USE TAT MODE TO READ CODE Selected model: C5212_m Selected com port: COM7 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35861 Phone SW: W259DDDA2 Phone BT ADDR: 44F4-59-FC89D5 Phone SN: R3WP598999 Deactivated MSL - TRUE [FREZEE]: 71980430 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00190906 Read info - ok Elapsed time: 16 second, sw ver: 3.5.0010 |
The Following User Says Thank You to milandhal For This Useful Post: |
11-24-2011, 08:44 | #13 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: India,Jaipur Age: 36
Member: 1189368 Status: Offline Sonork: 100.1614900 Thanks Meter: 91 | samsung w259 simlock done Quote:
12-29-2011, 11:43 | #14 (permalink) |
Freak Poster Join Date: Mar 2010 Location: delhi Age: 43
Member: 1260094 Status: Offline Thanks Meter: 33 | Selected com port: COM10 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35861903408003 Phone SW: W259DDEE3 Phone BT ADDR: 9463-D1-E40274 Phone SN: R3WP598999 Deactivated MSL - TRUE [FREZEE]: 14236070 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00013742 [Phone Lock]: 00000000 Read info - ok Elapsed time: 15 second, sw ver: 3.5.0030 ------------------------------------------------------------------------------- 100% work thanks u |
05-17-2012, 09:13 | #15 (permalink) | |
Freak Poster Join Date: May 2007 Location: india
Member: 517159 Status: Offline Thanks Meter: 21 | Quote:
--------------------------- 5/17/2012 1:33:52 PM ----------------------------- Selected model: C5212_m Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 358xxxxxxxxxxx Phone SW: W259DDDA2 Phone BT ADDR: D4E8-B2-147093 Phone SN: R3WPxxxxxx Deactivated MSL - TRUE [FREZEE]: 59590270 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 98989957 [Phone Lock]: 00000000 Read info - ok Elapsed time: 16 second, sw ver: 3.5.0035 | |
lots of service manuals Nokia, Siemens Sony Samsung etc. | -=KnOeFz=- | GSM Mobile Links | 4 | 11-16-2011 08:42 |
Nokia 3210 Mastercode +simlock | kraaiguy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-26-2000 14:13 |
SIMLOCK NOKIA 3210 V 4,43 | zibiss | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-23-1999 23:18 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
N6150 simlock open??? | Tommy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-21-1999 09:31 |
