Old 01-10-2013, 08:06   #1 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
Arrow samsung wave 3 ( s8600) unlocking problem
helo respected supporters , i have samsung s8600 (wave 3 ) , i tried to unlock it with new setup, but there is no patched apps file on support for this version , so how i can unlock it
here is log of the phone :-
eading phone info...
Model: GT-S8600
Country code: FTM
Cal date: ªU
Factory SW: S8600BVLD2
Unique number: c04902487b1db9f
Memory phone: ªU
Software version: S8600BVLD2/S8600FTMLD2
IMEI: 359516048364881
Product code: GT-S8600HKAFTM
Bypass MSL... error
Done with Samsung Tool v.13.8
Selected model: S8600
Selected port: COM10 Z3X BOX Serial Port
Selected port speed: 115200
Searching Samsung modem... detected COM19
Reading phone info...
Model: GT-S8600
Country code: FTM
Cal date: ªU
Memory phone: ªU
IMEI: 3595160483****
Bypass MSL... error
Old 01-10-2013, 08:56   #2 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
Arrow problem solved
my problem is solved, i took risk and i flashed wit this patched apps file
"apps_compressed_S8600JVLD1_Z3X"
then i press unlock button and phone gets unlocked , thanks to z3x team. really thanks
The Following 2 Users Say Thank You to jaggaamrit For This Useful Post:
Old 01-10-2013, 09:23   #3 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
here is screenshot
The Following 4 Users Say Thank You to jaggaamrit For This Useful Post:
Old 01-19-2013, 13:00   #4 (permalink)
Member: 1802988
Sonork: waleedabid
plz tell me i did flash with apps firmware installed from Information 4 All but still have bypass msl error,wht i need to do plz i need this urgent
Old 01-28-2013, 18:00   #5 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
can u post here log ,
Old 01-28-2013, 18:05   #6 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,515
you need flash apps from z3x special forlder firmwares
Old 06-02-2015, 09:45   #7 (permalink)
Member: 1085733
Sonork: 0244143040
thanks bro it worked 10000000000%
Old 03-21-2016, 16:39   #8 (permalink)
Member: 1187075
Thanks Meter: 10
S8600 unlock error
UNLOCK INSTRUCTIONS:
USB mode :
1. Power on phone.
2. Type *#197328640# -> common -> usb config -> Samsung mode
3. Connect phone to PC, install drivers if needed.
4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
Or you can 'Read User Lock' or 'Reset User Lock'.
Operation: Unlock
Selected model: GT-S8600
Software version: 20.5
Searching Samsung modem... detected COM91
Reading phone info... error
Done with Samsung Tool v.20.5
Give same error when imei rebuild because imei is inactive
Old 03-22-2017, 19:26   #9 (permalink)
yahia ali's Avatar
Member: 206173
Thanks Meter: 169
USB mode :
1. Power on phone.
Operation: Unlock
i have the sam prob any ide plz
Old 03-22-2017, 19:44   #10 (permalink)
noure30's Avatar
Member: 261437
Sonork: no
Thanks Meter: 922
flash patched apps file
then press unlock button and phone gets unlocked
Page generated in 0.20157 seconds with 8 queries
