12-26-2012, 10:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hafizabad, Pakistan
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | Sc-02c 4.0.3 how to unlock? Selected port: COM12 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM69 Reading phone info... Software version: SC02COMLPL/SC02CDCMLPL/SC02COMLPL/SC02COMLPL IMEI: 356881046221639 1 Product code: SGH-N033LKNDCM Done with Samsung Tool v.13.7 Selected model: SC02C Selected port: COM12 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SC-02C Android version: 4.0.3 Product code: SGH-N033LKNDCM Phone version: SC02COMLPL PDA version: SC02COMLPL CSC version: SC02CDCMLPL IMEI: Unknown Checking Super user right... false Rooting phone, please wait... error Not supported android version 4.0.3 Done with Samsung Tool v.13.7 |
12-26-2012, 13:34 | #5 (permalink) |
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | Selected model: SC02C Selected port: COM12 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SC-02C Android version: 4.0.3 Product code: SGH-N033LKNDCM Phone version: SC02COMLPL PDA version: SC02COMLPL CSC version: SC02CDCMLPL IMEI: Unknown Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.13.7 UNLOCK DONE |
The Following User Says Thank You to malikasim For This Useful Post: |
01-18-2013, 10:36 | #13 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Quote:
suggestion is it needs suitable root files for japnese SII i think u r using wrong root files check on xda developers there root files r avaialble. now solution is just flash it all will be ok and tested many times | |
03-01-2013, 14:35 | #15 (permalink) |
Registered User Join Date: May 2004 Age: 42
Member: 65987 Status: Offline Thanks Meter: 45 | GUIDE: 1. Download the CF-Root Kernel (CF-Root-SGS2_XX_NEE_LPD-v5.4-CWM5.zip, 6.2 MB) package to your computer. 2. Download Odin3 1.85 (Odin 1.85.zip, 200 kB) to your computer. 3. Extract the downloaded CF-Root Kernel ZIP file using any extracting software such as WinZIP or 7-Zip. Place the extracted file inside a single folder. Important! Do not extract the TAR file. 4. Extract Odin 1.85.zip and place the contents inside a single folder. On your PC, launch the Odin3 application by double-clicking Odin3 v1.85.exe. Switch off your Samsung Galaxy S2. 5. Boot your phone into Download Mode. You can do this by pressing and holding down the Volume Down, Home, and Power keys together until you are greeted with a Warning! screen. Press the Volume Up key to enter Download Mode. 6. Connect your Galaxy S2 to your PC via USB cable. You should see a message “Added!” under Odin’s message box found on the bottom-left of the application. This should indicate that your phone’s USB drivers have been installed. 7. In Odin3, click the PDA button, then browse for the CF-Root-SGS2_XX_NEE_LPD-v5.4-CWM5.tar file. Make sure that Repartition is not checked. 8. Important! Do not make any changes in Odin aside from the one’s mentioned in this tutorial. Doing so may cause irreversible damage to your device. Select the Start button in Odin to begin flashing the CF-Root Kernel on your Galaxy S2. Once the firmware has been installed, your phone should automatically reboot. A “PASS” message with a green background will be shown on the top-leftmost box of Odin. Disconnect your phone from your PC once you see the Samsung logo. 9. Congratulations! You have successfully rooted your Samsung Galaxy S2 GT-I9100 using Odin3. Enjoy the benefits of having a rooted device. |
