07-07-2018, 06:25 | #1 (permalink) |
Freak Poster Join Date: Aug 2015 Location: asdfsdf
Member: 2439634 Status: Offline Sonork: logimon999 Thanks Meter: 188 | SCV38 unlock problem? Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SCV38 Software version: 33.2 Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SCV38 Android version: 8.0.0 PDA version: SCV38KDU1ARCD CSC version: SC02KDCM1ARD3 Phone version: SCV38KDU1ARCD Product code: SM-G960JZPAKDI CSC country code: JP CSC sales code: DCM Phone SN: R58K42KADZY IMEI: 354631090500640 HW version: G960JPN.10 RF cal date: 2018.04.17 Chip name: SDM845 Modem board: SDM845 Security patch: 2018-04-01 Boot Warranty bit: 0 Searching Samsung diag port... detected COM1126 Reading phone info... OK Reading data from phone... error (1), skip Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM736 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 68371519 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.33.2 i entered unlock code but again ask code entered code again ask unlock code? what i do? |
11-14-2018, 10:19 | #11 (permalink) |
No Life Poster Join Date: Jun 2011 Location: Sukabumi
Member: 1594457 Status: Offline Sonork: 100.1646470 Thanks Meter: 145 | SAME PROBLEM PLEASE HELP !!! Operation: Read Codes via Server Selected model: SCV38 Software version: 34.3 Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SCV38 Android version: 8.0.0 PDA version: SCV38KDU1ARE4 CSC version: SCV38KDI1ARE4 Phone version: SCV38KDU1ARE4 Product code: SM-G960JZPAKDI CSC country code: JP CSC sales code: KDI Phone SN: R58K444Lxxx IMEI: 35463109060xxx HW version: G960JPN.10 RF cal date: 2018.04.24 Chip name: SDM845 Modem board: SDM845 Security patch: 2018-05-01 Boot Warranty bit: 0 SIM State: NETWORK_SUBSET_LOCKED Searching Samsung diag port... not found Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM19 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 24063529 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.3 |
