04-01-2017, 20:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | Security damaged (1) Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: Phone version: G925FXXU4DPG6 PDA version: G925FXXS3DPF3 CSC version: G925FOJV3DPB4 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: 00000000000 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2016-06-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.28.0 |
04-02-2017, 08:34 | #6 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: Phone version: G925FXXU4DPG4 PDA version: G925FXXS3DPF3 CSC version: G925FOJV3DPB4 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (9) Done with Samsung Tool PRO v.26.9 |
04-02-2017, 08:48 | #7 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: Phone version: G925FXXU4DPG4 PDA version: G925FXXS3DPF3 CSC version: G925FOJV3DPB4 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... Start... Card error OK Initialization... error (error(2)) Done with Samsung Tool PRO v.26.9 |
04-02-2017, 11:38 | #10 (permalink) | |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Quote:
Flash downgrade Modem only. | |
04-02-2017, 12:13 | #11 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G925F Software version: 24.8 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: Phone version: G925FXXU4DPG4 PDA version: G925FXXS3DPF3 CSC version: G925FOJV3DPB4 CSC country code: UAE CSC sales code: XSG HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Checking certificate file... OK KEY ID: 0346 Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (8) Done with Samsung Tool PRO v.24.8 |
04-02-2017, 12:16 | #13 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G925F Software version: 24.8 File analysis... OK Total file size: 0x02693FB0 (38 Mb) Searching USB Flash Interface... detected COM9 Setup connection... OK Reading PIT from phone... error Done with Samsung Tool PRO v.24.8 |
04-02-2017, 12:16 | #14 (permalink) |
