03-16-2017, 17:39 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: NJ, USA
Member: 399404 Status: Offline Thanks Meter: 70 | Security damaged G925T Help BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-G925T Software version: 27.8 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G925T Android version: 6.0.1 Product code: Phone version: G925TUVU5EPK5 PDA version: G925TUVU5EPK5 CSC version: G925TTMB5EPK5 CSC country code: USA CSC sales code: TMB HW version: Phone SN: 00000000000 Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.8 |
03-22-2017, 01:07 | #8 (permalink) |
Banned Join Date: Jan 2014 Location: Havana, Cuba Age: 40
Member: 2107306 Status: Offline Thanks Meter: 612 | Use other tool to 1 bypass knox 2 then write modem from combination with that rollback 3 finally use c3300k cable via UART and do IMEICERT_WRITE. The name of the tool you should figure it out by yourself. Rest of sure you will solve your problem. Hope it helps. |
The Following User Says Thank You to Prsctt For This Useful Post: |
