11-16-2014, 14:18 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | SGH-A157v AT&T unlock problem 1. select model B7722m from 2g programe 2. select files 3. connect cell with on position ( when cell connect with pc it show two option pc and charging only ) i dont select any option from it. 4. press read info but nothing happens also try 1st press read info and then connect cell to pc but same anybody halp me how i do unlock this cell. thnx |
11-16-2014, 14:36 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | PROCEDURE: - run z3x 2g tool - select model B7722_m - connect phone without battery using UART rj45 cable 3303k (Not USB) - click READ INFO - put battery and wait for codes - after read codes put non accepted sim card on phone and enter the codes read by Z3X. Last edited by maxpro12; 11-16-2014 at 14:43. |
11-17-2014, 07:27 | #5 (permalink) | |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Quote:
log: Selected model: B7722_m Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Timeout Timeout Phone fail TAT MODE Unlock - false Elapsed time: 24 second, sw ver: 3.5.0040 | |
11-17-2014, 13:46 | #6 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | when i received this cell it showed network code put in. 1st i tell you guys how i deal this cell from start step by step: a) i fully reset the cell with this code. *#2767*3855# b) then i put this code. #*7337# now my cell imei gone to 0000000000 so bad. now i want to unlock by z3x by above procedure but after connect cell nothing happen. and procedure failed. what i do to recover imei and also unlock my cell plzzzzzz anybody help me. thankss |
11-21-2014, 10:25 | #11 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Inside
Member: 455852 Status: Offline Sonork: 100.1596308 Thanks Meter: 1,993 | you are not alone can do you wrong all z3x users can do you must have good cable Selected model: B7722_m Selected com port: COM7 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 352307xxxxxxxxxxx Phone SW: A157UCLD1 Phone BT ADDR: 0012-47-000001 Phone SN: R21C50KB2X [FREZEE]:14789632 [NET LOCK]:24617780 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 [Sim LOCK]:12369874 [Activa LOCK]:12369874 Read info - ok Elapsed time: 25 second, sw ver: 3.5.0040 Last edited by djmurod86; 11-21-2014 at 10:34. |
11-21-2014, 13:28 | #12 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Kanada
Member: 737720 Status: Offline Thanks Meter: 1,421 | Quote:
