05-14-2015, 03:31 | #1 (permalink) |
No Life Poster Join Date: Oct 2010
Member: 1422878 Status: Offline Thanks Meter: 164 | SGH-A847D error read codes with Samsung Pro 2.1 Other model fail with Samsung Pro 2.1. This model is in the list of model supported by Samsung Pro 2.1, but this fail when try to read codes, what happend, this models are really supported? How can unlock this SGH-A847D? Code: UNLOCK INSTRUCTIONS: Read codes only USB cable : 1. Phone must be powered on. 2. Type *#782872# to switch phone to Qualcomm USB mode, (after operations you can enter *#726872# to switch back to Samsung USB mode.) 3. Connect USB cable, install drivers. 4. Select diagnostic port in port settings. 5. Enter *#7465625# (phone must display locks status). 6. Press 'Read codes' to read security codes. Operation: Read Codes Selected model: SGH-A847D Selected port: COM266 Software version: 21.0 Reading phone info... OK Model: SGH-A847D Country code: ij³ª´Ù/TLS Cal date: 2010-11-25 Factory SW: TLJK4 Unique number: 5516000100000 Memory phone: K5R2G1GACE(A847)S Phone S/N: RPWB529000 Reading IMEI... OK IMEI: 355831000000000 Reading software version... OK Phone version: A847TLJK4 Searching sysinfo... not found Done with Samsung Tool PRO v.21.0 |
11-21-2015, 22:27 | #2 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Somewhere on earth
Member: 2014742 Status: Offline Thanks Meter: 167 | Very disappointed, tried the other port too but same result. Operation: Read Codes Selected model: SGH-A847D Selected port: COM851 Qualcomm HS-USB Diagnostics 9002 Software version: 23.4 Reading phone info... OK Model: SGH-A847D Country code: ij³ª´Ù/TLS Cal date: 2010-11-25 Factory SW: TLJK4 Unique number: 55430001178106 Memory phone: K5R2G1GACE(A847)S Phone S/N: RRQBA55139 Reading IMEI... OK IMEI: 3558xxxxxxxxxxx Reading software version... OK Phone version: A847TLJK4 Searching sysinfo... not found |
