12-02-2009, 08:10 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Algeria
Member: 695274 Status: Offline Thanks Meter: 814 | SGOLD3 NEW9 the same bug............. Connecting to KM900 in UART Mode (COM7 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Main Loader answer timed OUT! BOOT Failed Disconnected. PMB8878 Module 1.0a started. SW: Ver 2.0.0.38 Connecting to KM900 in UART Mode (COM7 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Main Loader answer timed OUT! BOOT Failed Disconnected. PMB8878 Module 1.0a started. SW: Ver 2.0.0.38 Connecting to KM900 in UART Mode (COM7 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Main Loader answer timed OUT! BOOT Failed Disconnected. i try with other com-box (unibox) but the same problem |
12-02-2009, 08:42 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Sgold3 new9 still have bug SGOLD3 NEW9 STILL HAVE BUG ... Welcome to LG Infineon SGOLD3 TOOL v2x by NoNameŽ models count: 23 Welcome to Sgold3 Module!! Count supported models - 23 Disconnected. PMB8878 Module 1.0a started. SW: Ver 2.0.0.38 Connecting to KM900 in UART Mode (COM5 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Flash ID: FF00FF BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Unlock codes: NCK[0]: 1260681610289147 (LOCKED) Preprocessing FLS File.... Starting Flash Applet Opening "KM900AT-00-V10f-ARB-XXX-JUN-12-2009+0.fls"... Writing FLSSP Sending SEC pack... Done FLSSP Writing FLS:STATIC_EEP Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE Sending SEC pack... Writing FLS:CODE Done FLS:CODE Writing FLS:CUST_DISK Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK Sending SEC pack... Certificate Failed! AND MISMATCHING VERSION!!!! |
12-02-2009, 08:44 | #3 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Welcome to LG Infineon SGOLD3 TOOL v2x by NoNameŽ models count: 23 Welcome to Sgold3 Module!! Count supported models - 23 Disconnected. PMB8878 Module 1.0a started. SW: Ver 2.0.0.38 Connecting to KM900 in UART Mode (COM5 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Flash ID: FF00FF BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Preprocessing FLS File.... Starting Flash Applet Opening "KM900AT-00-V10b-EEU-XXX-MAY-05-2009+2.fls"... Writing FLSSP Sending SEC pack... Done FLSSP Writing FLS:STATIC_EEP Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE Sending SEC pack... Writing FLS:CODE Done FLS:CODE Writing FLS:CUST_DISK Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK Sending SEC pack... Certificate Failed! |
12-02-2009, 08:58 | #4 (permalink) |
Member: 695274 Status: Offline Thanks Meter: 814 | problem solved with free method http://www.forummobiles.com/index.php?showtopic=213565 plz plz Mr blank we need old card firmware 1.7 plz how to downgrade the firmware card |
12-02-2009, 09:38 | #7 (permalink) |
Member: 695274 Status: Offline Thanks Meter: 814 | this solution tested by me now and working http://www.forummobiles.com/index.php?showtopic=213565 use : III Flash avec FlashTool_E2 |
12-02-2009, 09:42 | #8 (permalink) |
Member: 695274 Status: Offline Thanks Meter: 814 | use SGOLD3 NEW 9FOR UNLOCK IS GOOD Disconnected. PMB8878 Module 1.0a started. SW: Ver 2.0.0.38 Connecting to KM900 in UART Mode (COM3 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Flash ID: FF00FF BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Unlock codes: NCK[0]: 6546668541211046 (LOCKED) |
12-02-2009, 09:44 | #9 (permalink) |
Member: 695274 Status: Offline Thanks Meter: 814 | SGOLD3 NEW9 succefull unlock KM900 Disconnected. PMB8878 Module 1.0a started. SW: Ver 2.0.0.38 Connecting to KM900 in UART Mode (COM3 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Flash ID: FF00FF BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Unlock codes: NCK[0]: 6546668541211046 (LOCKED) thank you Mr:blank |
12-02-2009, 09:48 | #10 (permalink) | |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Quote:
can i solve with your solution?!! | |
12-02-2009, 09:49 | #11 (permalink) | |
12-02-2009, 10:36 | #12 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | to z3xteam pleaese help urgent for km900 flash with z3x and now hang on version mismatching and use sgold3beta2new9 and error certificate please solve my problem .i need it. Welcome to LG Infineon SGOLD3 TOOL v2x by NoNameŽ models count: 23 Welcome to Sgold3 Module!! Count supported models - 23 Disconnected. PMB8878 Module 1.0a started. SW: Ver 2.0.0.38 Connecting to KM900 in UART Mode (COM5 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Flash ID: FF00FF BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Preprocessing FLS File.... Starting Flash Applet Opening "KM900AT-00-V10b-EEU-XXX-MAY-05-2009+2.fls"... Writing FLSSP Sending SEC pack... Done FLSSP Writing FLS:STATIC_EEP Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE Sending SEC pack... Writing FLS:CODE Done FLS:CODE Writing FLS:CUST_DISK Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK Sending SEC pack... Certificate Failed! |
12-02-2009, 11:00 | #13 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Kolkata,Kathmandu,
Member: 306096 Status: Offline Sonork: 100.1585877 Thanks Meter: 255 | change the battery and again try to flash............................. |
The Following User Says Thank You to umadineshdas For This Useful Post: |
Same bug on 2.6.7 | Borjina | Universalbox | 8 | 01-13-2009 05:08 |
same bug in v3.00 | bsb1106 | NSPRO | 0 | 05-21-2007 15:26 |
Himalaya flashing error, STILL SAME BUG AND NO UPDATE!!! | Stylo_GSM | JAFWM | 3 | 04-09-2007 06:43 |
Still Same Bug In New Vr 1.24 | MNGASHNET | MT-BOX | 20 | 11-16-2006 17:02 |
