12-03-2009, 01:55 | #17 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Testing version (Ver 2.0.0.42 from app info) and LG_Sgold3_Beta_2.0_new11.exe are already on support. So instructions : 1. Charge battery of KM900 to maximum 2. Select USB connection mode 3. Press connect and connect your phone , if you do it first time note that you need setup FlashTool drivers. Ex from attachment 4. You will se strange words in log , wait untill finished and your phone will be ok 5. If something go wrong post here log or screenshot , we will fix them Code: PMB8878 Module 1.0a started. SW: Ver 2.0.0.41 Please connect phone , it must be powered off Booting... \\.\USB1 Phone found! (MCU:SG3_USB) prebooting... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Preprocessing FLS File.... Starting Flash Applet Opening "KM900AT-00-V10b-EEU-XXX-MAY-05-2009+2.fls"... Writing FLS:DSP:../../../wou_build/OPERA_EUROPE_OPEN_RELEASE/MPEH_OPERA_EUROPE_OPEN.dsp Sending SEC pack... Done FLS:DSP Writing FLS:STATIC_EEP:MPEH_OPERA_EUROPE_OPEN.eep Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Sending SEC pack... Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Done FLS:CODE Writing FLS:CUST_DISK:OPERA_EUROPE_OPEN-CUST.dfat Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK:OPERA_EUROPE_OPEN-ROOT.dfat Sending SEC pack... Done FLS:ROOT_DISK Writing FLS:USER_DISK:OPERA_EUROPE_OPEN-USER.dfat Sending SEC pack... Done FLS:USER_DISK Writing FLS:PSI:psi_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:PSI Writing FLS:SLB:slb_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:SLB Writing FLS:UA:ua_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:UA Writing FLS:AMD_SINGLE:a250_single_image.fls Sending SEC pack... Done FLS:AMD_SINGLE Done! Last edited by NoName®; 12-03-2009 at 02:12. |
12-03-2009, 09:47 | #18 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® models count: 24 Welcome to Sgold3 Module!! Count supported models - 24 Disconnected. PMB8878 Module 1.0a started. SW: Ver 2.0.0.42 PMB8878 Module 1.0a started. SW: Ver 2.0.0.42 Please connect phone , it must be powered off Booting... \\.\USB1 Phone found! (MCU:SG3_USB) prebooting... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Unlock codes: NCK[0]: 1260681610289147 (LOCKED) Preprocessing FLS File.... Starting Flash Applet Opening "KM900AT-00-V10f-ARB-XXX-JUN-12-2009+0.fls"... Writing FLSSP:../../../wou_build/OPERA_EUROPE_OPEN_RELEASE/MPEH_OPERA_EUROPE_OPEN.dsp Sending SEC pack... Done FLSSP Writing FLS:STATIC_EEP:MPEH_OPERA_EUROPE_OPEN.eep Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Sending SEC pack... Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Done FLS:CODE Writing FLS:CUST_DISK:OPERA_EUROPE_OPEN-CUST.dfat Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK:OPERA_EUROPE_OPEN-ROOT.dfat Sending SEC pack... Done FLS:ROOT_DISK Writing FLS:USER_DISK:OPERA_EUROPE_OPEN-USER.dfat Sending SEC pack... Done FLS:USER_DISK Writing FLS:PSIsi_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:PSI Writing FLS:SLB:slb_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:SLB Writing FLS:UA:ua_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:UA Writing FLS:AMD_SINGLE:a250_single_image.fls Sending SEC pack... Done! thanks verymuch. km900 now work.with this firmware. |
12-04-2009, 14:50 | #20 (permalink) |
No Life Poster Join Date: Jul 2001
Member: 5243 Status: Offline Thanks Meter: 80 | Code: Disconnected. PMB8878 Module 1.0a started. SW: Ver 2.1.0.49 Please connect phone , it must be powered off Booting... \\.\USB1 BOOT Stage Finished , sending authority... Sending SEC pack... Certificate Failed! |
12-04-2009, 15:03 | #21 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,550 | Quote:
12-04-2009, 16:09 | #23 (permalink) |
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Starange try to connect cable to another usb port , maybe link to long , I am dont know whats wrong , flashed test phone in lab 100 times |
12-04-2009, 18:15 | #24 (permalink) |
Member: 5243 Status: Offline Thanks Meter: 80 | new port, connected WITHOUT battery, and flashed first time, thanks guys. Code: PMB8878 Module 1.0a started. SW: Ver 2.1.0.49 Please connect phone , it must be powered off Booting... \\.\USB1 Phone found! (MCU:SG3_USB) prebooting... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Unlock codes: NCK[0]: 3468720272240125 (LOCKED) Preprocessing FLS File.... Starting Flash Applet Opening "KM900AT-00-V10b-EEU-XXX-MAY-05-2009+2.fls"... Writing FLS:DSP:../../../wou_build/OPERA_EUROPE_OPEN_RELEASE/MPEH_OPERA_EUROPE_OPEN.dsp Sending SEC pack... Done FLS:DSP Writing FLS:STATIC_EEP:MPEH_OPERA_EUROPE_OPEN.eep Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Sending SEC pack... Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Done FLS:CODE Writing FLS:CUST_DISK:OPERA_EUROPE_OPEN-CUST.dfat Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK:OPERA_EUROPE_OPEN-ROOT.dfat Sending SEC pack... Done FLS:ROOT_DISK Writing FLS:USER_DISK:OPERA_EUROPE_OPEN-USER.dfat Sending SEC pack... Done FLS:USER_DISK Writing FLS:PSI:psi_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:PSI Writing FLS:SLB:slb_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:SLB Writing FLS:UA:ua_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:UA Writing FLS:AMD_SINGLE:a250_single_image.fls Sending SEC pack... Done! |
Same bug on 2.6.7 | Borjina | Universalbox | 8 | 01-13-2009 05:08 |
same bug in v3.00 | bsb1106 | NSPRO | 0 | 05-21-2007 15:26 |
Himalaya flashing error, STILL SAME BUG AND NO UPDATE!!! | Stylo_GSM | JAFWM | 3 | 04-09-2007 06:43 |
Still Same Bug In New Vr 1.24 | MNGASHNET | MT-BOX | 20 | 11-16-2006 17:02 |
