06-24-2016, 08:30 | #1 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1412183 Status: Offline Thanks Meter: 27 | shv-e210s imei 0000000 porblem ihave shv-e210s imei 0000000000 i fisrt flash the phone then root repeir imei chk but failed REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Repair Selected model: SHV-E210S Software version: 25.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SHV-E210S Android version: 4.3 Product code: Phone version: E210SKSNA2 PDA version: E210SKSUGNA2 CSC version: E210SSKTGNA2 CSC country code: KOREA CSC sales code: SKT HW version: Phone S/N: Modem board: RF cal date: IMEI: 000000000000000 Checking Super user right... true Reading nv data... OK Security damaged Done with Samsung Tool PRO v.25.7 plz give me good efs shv-210s file and soltion |
The Following User Says Thank You to sadiq25930 For This Useful Post: |
