07-17-2017, 20:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Sm-120az latest **** securtiy qd2 If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Opération:Read Codes Modèle sélectionné:SM-J120AZ Version du logiciel:28.8.1 RechercheSamsung modem... détécté COM29 Lecture d'information du telephone... Ok Modèle: SM-J120AZ AP version: J120AZTUS3AQD2 CSC version: J120AZAIO3AQD2 CP version: J120AUXXXXXXXXX Code du produit: SM2J120AZKZAIO Téléphones SN: R58HC5EKXZX Numéro unique: CFN002089F20DB3 LectureIMEI... Ok IMEI: 356419077890731 (SIGN: OK) Vérification du dossier hash... Ok Lecture données du Téléphone... Ok Prise modem: SHANNON308 HWID: B3 2F D1 62 91 B1 D1 58 62 61 28 C1 AE 0A 57 E7 LectureNV data... Ok VérificationNV data ... Ok Calcul... Ok S'il vous plaît attendre, le calcul des codes... OK (heure -00:00:12) Freeze code: 50682627 NET verrou: 04917047 SUB verrou: 00000000 SP verrou: 00000000 CP verrou: 00000000 SIM verrou: 00000000 Pour connaître l'état de verrouillage : *#7465625# Fait avecSamsung Tool PRO v.28.8.1 |
07-18-2017, 05:37 | #5 (permalink) |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Flash the combo modem COMBINATION_ATT_FA60_J120AUCU3AQE1 if you dont have the combo take the long way Flash the eng boot PC1. Root with kingroot (3-4 times) And read codes with root 100% working Here the log for the last compilation QE1 Operation: Read Codes Selected model: SM-J120AZ Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SAMSUNG-SM-J120AZ Android version: 6.0.1 Product code: SM2J120AZKZAIO Phone version: J120AZTUS3AQE1 PDA version: J120AZTUS3AQE1 CSC version: J120AZAIO3AQE1 CSC country code: USA CSC sales code: AIO HW version: REV0.3 Phone SN: Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-05-01 RF cal date: 20170224 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: 47 1A 40 E0 62 50 C7 6F D9 3C CB 37 AE F7 D3 0A Calculating... Ok Checking hash file... Ok Please wait, calculating codes... OK (time - 00:00:04) Freeze code: 81684815 NET lock: 79050736 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# |
07-18-2017, 05:38 | #6 (permalink) |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Yes correct bro Envoyé de mon VS500 en utilisant Tapatalk |
The Following User Says Thank You to ghacks For This Useful Post: |
08-17-2017, 00:09 | #8 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | did boot and modem then kingroot then z3x-pro read code Operation: Read Codes Selected model: SM-J120AZ Software version: 29.1 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-J120AZ Android version: 6.0.1 Product code: SM2J120AZKZAIO Phone version: J120AUCU3AQE1 PDA version: J120AZTUS3AQE1 CSC version: J120AZAIO3AQE1 CSC country code: USA CSC sales code: AIO HW version: REV0.3 Phone SN: R58HC01WSMZ Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-05-01 RF cal date: 20161201 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 87 31 3B 3E E1 DA 32 A5 C4 B2 38 40 F7 2A E0 57 Calculating... OK Checking hash file... OK Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 37949515 NET lock: 02581906 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.1 |
