09-06-2017, 09:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | Sm-a310f imei repair done (write cert) android 7 Code: BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-A310F Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-A310F Android version: 7.0 Product code: SM-A310FZWDMID Phone version: A310FXXU3CQF8 PDA version: A310FXXU3CQF5 CSC version: A310FOJV3CQF6 CSC country code: Iraq CSC sales code: MID HW version: MP 0.200 Phone SN: R58H44B5T9J Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-06-01 RF cal date: 20160426 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 0B 68 93 EE D6 BC 9B 6D D4 CD 91 7B FC E6 7A C6 Calculating... OK Initialization AT RIL... AT RIL stopped, restarting... OK Checking for compatible phone and cert Phone KEY ID: 0017 Checking certificate file... OK KEY ID: 0017 Crypting CERT 1... OK Crypting CERT 2... OK Writing NV data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.29.2 |
The Following 2 Users Say Thank You to Moh3en.pc For This Useful Post: |
