01-03-2017, 06:09 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Octoplus Team
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | SM-A500H Need repair imei ? How to repair imei ? Code: BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-A500H Selected port: Software version: 27.7 Checking CERT file... Ok KEY ID: 0756 Waiting ADB device... Ok Reading phone info... Model: SM-A500H Android version: 5.0.2 Product code: Not Active Phone version: A500HXXU1BOF6 PDA version: A500HXXU1BOJ1 CSC version: A500HOXY1BOJ1 CSC country code: Central Asia CSC sales code: CAC HW version: Phone SN: 00000000000 Modem board: MSM8216 RF cal date: NONE IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... error This CERT file is not compatible for this phone, KEY ID: 0387 Done with Samsung Tool PRO v.27.7 |
