04-16-2017, 20:10 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Sudan
Member: 219803 Status: Offline Sonork: 1582317 Thanks Meter: 38 | SM-A520F/DS Successfully remove FRP Yep Chose G531H/DS Operation: Reset FRP Selected model: SM-G531H/DS Software version: 28.1 Waiting ADB device... Ok Reading phone info... Model: SM-A520F Android version: 6.0.1 Product code: SM-A520FZKD Phone version: A520FXXU1AQC1 PDA version: A520FXXU1APLO CSC version: CSC country code: CSC sales code: HW version: MP 0.400 Phone SN: R28J22P7Y4L Chip name: EXYNOS7880 Modem board: SHANNON325 Security patch: 2016-12-01 RF cal date: 20170218 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.1 Thanks Z3X Team |
The Following 4 Users Say Thank You to zozo2 For This Useful Post: |
04-19-2017, 15:07 | #2 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Kenya
Member: 70343 Status: Offline Thanks Meter: 38 | Quote:
04-19-2017, 20:18 | #3 (permalink) | |
No Life Poster Join Date: Sep 2012 Location: UK
Member: 1816005 Status: Offline Thanks Meter: 299 | Quote:
or go to settings and try to enable developer options---> oem unlock if it shows it | |
04-20-2017, 08:57 | #4 (permalink) | |
With download mode, ResetFRP/React/EE: UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G531H/DS Software version: 28.1 Searching Samsung USB Flash interface... COM3 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... Ok Erasing Reactivation lock... error Done with Samsung Tool PRO v.28.1 With normal mode, Reset FRP: Waiting ADB device... Ok Reading phone info... Model: SM-A520F Android version: 6.0.1 Product code: SM-A520FZDDTHL Phone version: A520FXXU1AQC1 PDA version: FA60_A520FXXU1AQC2 CSC version: CSC country code: CSC sales code: HW version: MP 0.400 Phone SN: R58J22V69YH Chip name: EXYNOS7880 Modem board: SHANNON325 Security patch: 2016-12-01 RF cal date: 20170221 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.1 Both options have failed, FRP still on. Any other suggestions would be appreciated. | |
06-17-2017, 16:04 | #5 (permalink) |
Junior Member Join Date: Oct 2007 Location: Bulgaria
Member: 615941 Status: Offline Thanks Meter: 1 | Flash sboot*bin and boot*img from combination firmware. Phone ask for pasword Turn off and reset with key combination Insert worked Sim Card with internet /Wi-Fi not turn on/ Reset FRP with Octopus and read carefuly every step Flash phone with smart switch with original firmware |
08-11-2017, 18:55 | #8 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Gambia
Member: 1440837 Status: Offline Sonork: 3535 Thanks Meter: 47 | Searching Samsung USB Flash interface... COM237 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... error Done with Samsung Tool PRO v.29.0 |
The Following User Says Thank You to trustunlockc For This Useful Post: |
09-24-2017, 08:40 | #9 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: indonesia
Member: 658821 Status: Online Thanks Meter: 12 | Quote:
solve with file combination from support tick sboot and boot..... | |
10-23-2017, 07:53 | #12 (permalink) |
Junior Member Join Date: Jul 2014 Location: Russia Lipetsk Age: 40
Member: 2220376 Status: Offline Thanks Meter: 4 | |
11-13-2017, 12:30 | #13 (permalink) |
Freak Poster Join Date: Oct 2010 Location: USA
Member: 1420095 Status: Offline Thanks Meter: 214 | Here's how I managed to remove FRP on A520F. First, flash combination file from Z3X. 2nd, Download official firmware (5 files) 3rd, Flash the following in Odin. - BL (insert BL file) - AP (insert AP file) - CP (Do not insert anything/leave it blank) - CSC (insert HOME file... instead of CSC) 4th, Wait for phone to turn on and "FRP" is gone. Done! |
The Following 14 Users Say Thank You to himig_natin For This Useful Post: |
11-14-2017, 14:09 | #14 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: Iran.ahar
Member: 811264 Status: Offline Sonork: 100.1638656 Thanks Meter: 231 | Quote:
Works fine for me. | |
The Following 2 Users Say Thank You to alishams123 For This Useful Post: |
12-04-2017, 14:06 | #15 (permalink) |
Insane Poster Join Date: Feb 2015 Location: Buea, Cameroon Age: 32
Member: 2347074 Status: Offline Thanks Meter: 30 | All I did was use Z3X Box and choose model number SM-G928P, put phone in download mode and Hit "Reset FRP/React/EE" and it worked like a charm! When the phone booted I went into developer settings and enabled OEM unlock then performed a factory reset. Easy-peasy. Build Number: A520FXXU2BQIH on Android 7.0 |
The Following 10 Users Say Thank You to dspurs For This Useful Post: |
