03-20-2016, 15:26 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: king of saudia arabia
Member: 2501469 Status: Offline Sonork: speakme2009 Thanks Meter: 33 | sm-A710F frp reset not complate with z3x pro? i have sm-a710f frp on not complate with last pro UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Pattern lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. Operation: Reset Pattern Lock Selected model: SM-A710F Software version: 24.8 Searching USB Flash Interface... detected COM9 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... time out Phone not found Done with Samsung Tool PRO v.24.8 |
