02-19-2017, 06:34 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 327489 Status: Offline Thanks Meter: 56 | SM-A710MUBU2BPL1 baseband unknown REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-A710M Software version: 27.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-A710M Android version: 6.0.1 Product code: Phone version: PDA version: A710MUBU2BPL1 CSC version: A710MZTO2BPL1 CSC country code: Brazil CSC sales code: ZTO HW version: Phone SN: RF1D45EJGGR Chip name: EXYNOS7580 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Can not detected modem type Done with Samsung Tool PRO v.27.7 ---------------------------------------------- Operation: Write CERT Selected model: SM-A710M Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-A710M Android version: 6.0.1 Product code: Phone version: PDA version: A710MUBU2BPL1 CSC version: A710MZTO2BPL1 CSC country code: Brazil CSC sales code: ZTO HW version: Phone SN: RF8H60SRZ3H Chip name: EXYNOS7580 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.7 thanks in advance |
