08-31-2017, 13:01 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | SM-C5010 Erasing FRP lock... error Software version: 29.2 Searching Samsung USB Flash interface... COM276 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... error Done with Samsung Tool PRO v.29.2 |
01-26-2018, 16:19 | #4 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Cuba
Member: 346150 Status: Offline Sonork: 100.1661091 Thanks Meter: 427 | Firmware version c5010zhu1aqg5 Searching Samsung USB Flash interface... COM26 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... error Done with Samsung Tool PRO v.30.5 |
04-05-2018, 04:31 | #11 (permalink) |
No Life Poster Join Date: Sep 2010 Location: PNG Papua New Guinea
Member: 1395476 Status: Offline Sonork: Men7896 Thanks Meter: 52 | I have same issue. phone flash to latest version ZZH1BQL5 from Z3X server Z3X tool ver v31.1 here is the log: Operation: Reset FRP/React/EE Selected model: SM-C5010 Software version: 31.1 Searching Samsung USB Flash interface... COM3 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... error Done with Samsung Tool PRO v.31.1 Any help? Thanks Regards |
The Following User Says Thank You to Men7896 For This Useful Post: |
04-05-2018, 04:42 | #12 (permalink) |
No Life Poster Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | If it's on 7.0 flash full combination, then flash stock system/boot only https://shell.boxwares.com/Download.aspx?L=2394 If 6.0 use this to enable adb https://shell.boxwares.com/Download.aspx?L=2423 If none of above work, downgrade to C5010ZCU1AQC1 and use eng boot to enable adb, then use adb commands or select any model such as g930p and use adb frp method https://updato.com/firmware-archive-...ir=asc&exact=1 |
04-06-2018, 00:32 | #13 (permalink) | |
Member: 1395476 Status: Offline Sonork: Men7896 Thanks Meter: 52 | Quote:
downloaded files but unable to reflash any other solution? Thanks Regards | |
