04-23-2016, 12:59 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: OUT OF CONTROL
Member: 536012 Status: Offline Sonork: 100.1660617 Thanks Meter: 120 | Sm-e700h android 5.1.1 unlock problem z3x_25.2 Instruction in Tools for Unlock : Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. But Cant find ADB in Unlock Section, Only COM Settings available. but Backup Or Repair Tab include ADB... How can Unlock This Phone Without ADB setting |
04-24-2016, 11:27 | #4 (permalink) | |
Member: 536012 Status: Offline Sonork: 100.1660617 Thanks Meter: 120 | Quote:
this phone unlock Via ADB only.so this is problem of z3x soft. | |
