10-23-2017, 21:37 | #16 (permalink) | |
Junior Member Join Date: Apr 2013
Member: 1926083 Status: Offline Thanks Meter: 2 | 1000000% worked thank you Quote:
The Following User Says Thank You to Mr cellie For This Useful Post: |
12-22-2017, 22:29 | #18 (permalink) |
Junior Member Join Date: Oct 2015 Location: Harare Zimbabwe
Member: 2475559 Status: Offline Thanks Meter: 7 | Operation: Reset FRP/React/EE Selected model: SM-G361H/DS Software version: 30.1 Searching Samsung USB Flash interface... COM14 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.30.1 thanks bro. it worked by selecting g361h/ds only |
The Following 4 Users Say Thank You to tambudzaib For This Useful Post: |
02-06-2018, 17:25 | #20 (permalink) | |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 578 | Quote:
thx for sharing with us | |
02-09-2018, 22:49 | #21 (permalink) |
Crazy Poster Join Date: Jan 2008
Member: 670300 Status: Offline Thanks Meter: 6 | I am having the problem. Below is the log. I flashed "G360T1UVU1AOFA_TMB1AOFA" and tried to do the FRP reset and got the below error. Any help please! Operation: Reset FRP/React/EE Selected model: SM-G360T1 Software version: 30.7 Searching Samsung USB Flash interface... COM24 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... error Done with Samsung Tool PRO v.30.7 |
02-09-2018, 22:51 | #22 (permalink) | |
Freak Poster Join Date: Jun 2017
Member: 2730595 Status: Offline Thanks Meter: 13 | Quote:
Plz flash combination file then do FRP reset Sent from my iPhone using Tapatalk | |
02-09-2018, 23:10 | #23 (permalink) |
Member: 670300 Status: Offline Thanks Meter: 6 | Since I have the TMobile phone so I download just the TMobile file from below link. Am I right? Finally for Tmo, flash only the boot.img from this package: https://www.androidfilehost.com/?fid=457095661767155675 |
02-09-2018, 23:35 | #24 (permalink) |
Member: 670300 Status: Offline Thanks Meter: 6 | Actually I followed tabbudzaid's method. I selected "SM--G361H/DS" instead of "SM-G360T1" and did the FRP and it worked. No need to flash the boot file. It worked for me. Operation: Reset FRP/React/EE Selected model: SM-G361H/DS Software version: 30.7 Searching Samsung USB Flash interface... COM24 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.30.7 |
The Following User Says Thank You to hapishyguy For This Useful Post: |
06-22-2018, 05:51 | #25 (permalink) | |
Junior Member Join Date: Mar 2012
Member: 1739144 Status: Offline Thanks Meter: 0 | Quote:
thanks for this solutions it works for me thanks a lot | |
07-31-2018, 08:12 | #26 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: Majuro, Marshall Islands
Member: 1227040 Status: Offline Sonork: 100:1654728 Thanks Meter: 55 | Quote:
1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-G361H/DS Software version: 33.4 Searching Samsung USB Flash interface... COM17 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.33.4 | |
08-25-2018, 17:46 | #27 (permalink) |
Freak Poster Join Date: Jun 2003 Location: FLA, US Age: 46
Member: 31969 Status: Offline Thanks Meter: 13 | SM-G360T1 FRP unlock error G360T1UVU2AQD1, not rooted Operation: Reset FRP/React/EE Selected model: SM-G360T1 Software version: 33.5 Searching Samsung USB Flash interface... COM6 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... error Done with Samsung Tool PRO v.33.5 I tried to select G360T - same error Last edited by toshik; 08-25-2018 at 17:55. |
08-26-2018, 00:12 | #28 (permalink) |
Member: 31969 Status: Offline Thanks Meter: 13 | This http://forum.gsmhosting.com/vbb/f453.../#post12545557 worked like charm thanks! How do I SIM unlock Metro version? If I do unlock from the program it asks me for some server login - not worth paying for this tiny cheap phone... |
09-14-2018, 14:42 | #29 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Zimbabwe, mutare
Member: 1957238 Status: Offline Thanks Meter: 80 | no need to download whole package just use below files and select g361f for frp reset download mode https://doc-0s-2k-docs.googleusercon...Pe7?e=download |
