08-04-2015, 10:25 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: india
Member: 1505730 Status: Offline Sonork: 100.1618029 Thanks Meter: 207 | SM-G361H unlock |
The Following User Says Thank You to bikku.gupta For This Useful Post: |
08-31-2015, 13:27 | #2 (permalink) |
Insane Poster Join Date: Jun 2015 Location: cox'sbazar
Member: 2413796 Status: Offline Sonork: 100.1661572:Wahid Thanks Meter: 52 | g361h unlock done z3x without root samsung tool pro 22.4 g361h unlock done z3x without root samsung tool pro 22.4. read code 100000000000000% |
The Following User Says Thank You to wahidulislam39 For This Useful Post: |
09-21-2015, 08:26 | #9 (permalink) |
Freak Poster Join Date: Nov 2007 Location: THE GREAT INDIA
Member: 622862 Status: Offline Thanks Meter: 52 | Ulock done without rooting with z3x tool pro UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-G361H Software version: 22.6 Searching Samsung modem... detected COM18 Reading phone info... OK Model: SM-G361H Version: G361HXXU0AOG3/G361HOJV0AOG1/G361HXXU0AOF8/G361HXXU0AOG3 Product code: SM-G361HZSDKSA Phone S/N: R51G82VPHAW Imei: 35420xxxxxxxxxx Unique number: CQN009AF390B182 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:16) Freeze code: 72729648 NET lock: 28184693 For check lock status: *#7465625# Done with Samsung Tool PRO v.22.6 |
09-21-2015, 09:28 | #10 (permalink) |
Freak Poster Join Date: Oct 2014 Location: India
Member: 2282226 Status: Offline Thanks Meter: 52 | please help : http://forum.gsmhosting.com/vbb/f453...-code-1993646/ |
01-06-2016, 07:37 | #14 (permalink) |
Freak Poster Join Date: Jul 2014 Location: bangladesh
Member: 2227733 Status: Offline Thanks Meter: 69 | G361H/DS read code done UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-G361H/DS Software version: 23.9 Searching Samsung modem... detected COM16 Reading phone info... OK Model: SM-G361H Version: G361HXXU0AOJ1/G361HOJV0AOH1/G361HXXU0AOJ1/G361HXXU0AOJ1 Product code: SM-G361HZWDKSA Phone S/N: R51G82FYXFW Imei: 3542020xxxxxxxx Unique number: CQN0088B7D8D582 Reading codes... OK Please wait, calculating codes... OK (time - 00:02:31) Freeze code: 42607359 NET lock: 94846268 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.9 |
