06-16-2015, 02:54 | #2 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | Did you backup the efs? If not then you need one filled with 0's. Flash it over the phone. For that you'll need the efs locations on the phone. Never meddled with one of these, but I do hope I may lead you to something |
06-16-2015, 03:27 | #7 (permalink) |
Member: 2273678 Status: Offline Thanks Meter: 293 | Ok, does this phone use certs? If so write a cert onto it, it should be able to fix your issue. If it doesn't proceed to a normal imei repair and that should fix your issue |
06-16-2015, 04:18 | #9 (permalink) |
Insane Poster Join Date: Mar 2010
Member: 1249625 Status: Offline Thanks Meter: 17 | Still unknown imei Operation: Write EFS Selected model: SM-G530FZ Selected port: COM3 Z3X BOX Serial Port, Software version: 21.4 Waiting ADB device... OK Reading phone info... Model: SM-G530FZ Android version: 4.4.4 Product code: Not Active Phone version: G530FZXXU1AOB1 PDA version: G530FZXXU1AOD1 CSC version: G530FZDBT1ANL4 CSC country code: Poland CSC sales code: XEO HW version: Phone S/N: Modem board: MSM8916 RF cal date: NONE IMEI: Checking Super user right... true Extracting EFS file... OK Converting img to ext4... OK Writing EFS to phone... OK Rebooting phone... OK Done with Samsung Tool PRO v.21.4 |
06-16-2015, 05:52 | #10 (permalink) |
No Life Poster Join Date: Aug 2008 Location: PhnomPenh Cambodia
Member: 846616 Status: Offline Sonork: 100.1675590 Thanks Meter: 581 | you have backup security before process unlocking? check in backup folder on z3x because z3x software always auto backup for when u process something with phone try!!!!! |
06-16-2015, 07:55 | #11 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
if you killed imei by other tool you need ask other tool to help you repair, if you killed imei by z3x - then just flash autobackup. if you losed backup you need buy or find cert file and write to phone. | |
06-16-2015, 13:56 | #12 (permalink) | |
Member: 1249625 Status: Offline Thanks Meter: 17 | Quote:
as u see i flashed oother efs but no imei | |
06-18-2015, 23:49 | #14 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2213792 Status: Offline Thanks Meter: 0 | Frist root & install cvm custom recovery to phone Go to custom recovery Connect phone to pc &Try ing riset defult imel to z3x box Turn up phone & white imel Your efs/mount problem recoulved!! |
