01-31-2016, 17:57 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | SM-G530T msl error 24.2 BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-G530FZ Selected port: COM18 SAMSUNG Mobile USB Serial Port Software version: 24.2 Checking certificate file... OK KEY ID: 0816 Waiting ADB device... OK Reading phone info... Model: SM-G530T Android version: 5.1.1 Product code: Not Active Phone version: G530TUVU1AOF8 PDA version: G530TUVU1AOF8 CSC version: G530TTMB1AOF8 CSC country code: USA CSC sales code: TMB HW version: Phone S/N: R28GB1AYMXF Modem board: MSM8916 RF cal date: NONE IMEI: Incorrect model selected. This may damage your phone. Continue? Yes Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.24.2 |
08-29-2016, 20:08 | #2 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277857 Status: Offline Thanks Meter: 68 | Any solution to this? I've read through the forums, but nothing explaining how to do get past this error. MSL reset is successful, but still error in writing CERT. Is eng boot needed? Operation: Write CERT Selected model: SM-G530FZ Selected port: COM66 SAMSUNG Mobile USB Serial Port Software version: 26.6 Checking certificate file... OK KEY ID: 0816 Waiting ADB device... OK Reading phone info... Model: SM-G530T Android version: 5.1.1 Product code: SM2G530TZAATMB Phone version: G530TUVU1APG1 PDA version: G530TUVU1APG1 CSC version: G530TTMB1APG1 CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone S/N: Modem board: MSM8916 RF cal date: 2015.11.12 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.26.6 |
08-30-2016, 02:05 | #3 (permalink) |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | only way exist a solution use a combinaison file bro Home Page | GEM Flash Firmware Free Download |
