08-04-2019, 22:37 | #137 (permalink) |
Insane Poster Join Date: Jun 2009
Member: 1046899 Status: Offline Thanks Meter: 6 | frp remove is simple for this model, follow instruction and you will have phone working 100% 1- flash combination file(not sboot), phone will start in maintenance mode 2- get stock firmware for g532f, do not flash yet 3- you need only 1 file which is AP file, and u need 7zip installed to pc 4- right click and use 7zip to open archive, and copy recovery.img, secro.img, system.img only, do not copy boot and userdata 5- in the folder that you now have these 3 files, select all and right click and use 7zip to add to archive format should be tar 6- now load this file using odin or z3x 7- put phone again in download mode and flash it 8- abra-cadabra your phone no longer has an frp user lock this method can be used to remove practically all new samsung phones, cheers |
The Following 2 Users Say Thank You to cha09 For This Useful Post: |
