Old 05-12-2020, 10:28   #1 (permalink)
Member: 2312129
Thanks Meter: 139
SM-G532F FRP done but FRP still ON
UNLOCK INSTRUCTIONS:
Direct unlock:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To read security codes (without root permissions):
5. Press 'Read codes' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
Operation: Reset FRP
Selected model: SM-G532F
Software version: 39.9
You must activate ADB before reset FRP Yes
Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-G532F
Android version: 6.0.1
PDA version: G532FXWU1ARE1
CSC version: G532FOJV1ARE1
Phone version: G532FXXU1ARB1
Product code: SM-G532FZSDECT
CSC country code: Nigeria
CSC sales code: ECT
Phone SN: R58J136RJFH
IMEI: 357063080730168
HW version: MP 0.300
RF cal date: 20170114
Chip name: MT6737T
Modem board: MT6737T
Security patch: 2018-05-01
Boot Warranty bit: 0
SIM State: ABSENT,ABSENT
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.39.9
DONE MANY TIMES SAME THING
Old 05-13-2020, 07:29   #2 (permalink)
Member: 2807070
Sonork: 550000
Thanks Meter: 37
Direct unlock:
Model: SM-G532F
CSC sales code: ECT
Chip name: MT6737T
Bypass FRP... OK
when frp bypass ok do next next or restart phone i did many time
Page generated in 0.15982 seconds with 8 queries
