02-23-2018, 09:10 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: the moon
Member: 1740779 Status: Offline Thanks Meter: 143 | Sm-g532m frp reset z3x NOTE: some G532M work when you do the full flash of the combo file but in most it doesn’t, Z3X just throws a false message of success but the FRP is still activated the only way I got FRP off was the above method. After flashing the Boot.img the phone restarts but you should be stuck at the Samsung logo, if this happens just do the hard reset in the recovery menu and Factory data wipe. After the phone starts back up normally and you connect it to the computer you should get a request for USB debug permission on the phone. |
The Following 4 Users Say Thank You to vaevictus0321 For This Useful Post: |
03-05-2018, 17:49 | #2 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2797726 Status: Offline Thanks Meter: 2 | PRIMERO DESCARGAR EL ARCHIVO : COMBINATION_UUB_FA60_G532MUBU1APJ1_UUB1APJ1 SI NO FUNCIONA DESCARGAR OTRO COMBINATION! *DESCOMPRIMIR EL ARCHIVO: COMBINATION_UUB_FA60_G532MUBU1APJ1_UUB1APJ1 *LUEGO ABRIR ODIN, SELECCIONAR AP Y BUSCAR EL COMBINATION *CUANDO SE TERMINE EL PROCESO INICIAR EL TELEFONO *ABRIR AJUSTES/ HABILITAR DEPURACION USB *LUEGO SELECCIONAR EN EL MENU DE SAMSUNG TOOLS / DESBLOQUEAR/ SELECCIONAR ADB,CONCEDER PERMISOS/ *UNA VEZ HECHO ESO SEGUIR DONDE DICE "RESET FRP" *COMENZARA ESTE PROCESO : UNLOCK INSTRUCCIONES: Direct unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To read security codes (without root permissions): 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Reset FRP Selected model: SM-G532M Software version: 30.8 Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SM-G532M Android version: 6.0.1 Código del Producto: SM-G532MZDADOR Versión del telefono: G532MUBU1APIH PDA version: FA60_G532MUBU1APJ1 CSC version: Código de país CSC: Código de Venta CSC: HW version: MP 0.300 Phone SN: RV8J61C0FPF Chip name: MT6737T Módem: MT6737T Security patch: 2016-09-05 RF cal date: 20170622 IMEI: ************* Bypass FRP... Listo For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.8 *UNA VEZ HECHO FLASH EL ARCHIVO G532MUMU1AQL3 *Y TENEMOS NUESTRO EQUIPO SIN FRP! |
