09-09-2017, 18:48 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | SM-G532M unlock done latest build Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Unlock Selected model: SM-G532M Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-G532M Android version: 6.0.1 Product code: Phone version: PDA version: G532MUMU1AQG5 CSC version: CSC country code: CSC sales code: HW version: Phone SN: Chip name: MT6737T Modem board: Security patch: 2017-07-01 RF cal date: IMEI: Checking Super user right... true Reading security... OK Unlocking... OK Writing security... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
The Following User Says Thank You to ghacks For This Useful Post: |
09-10-2017, 00:05 | #3 (permalink) |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | bro |
