09-19-2017, 06:26 | #1 (permalink) |
Freak Poster Join Date: Jan 2015 Location: manshera,Pakistan
Member: 2330556 Status: Offline Thanks Meter: 79 | Sm-g5700 frp erase [Done] PS.DON'T FORGET TO PRESS THANKS. |
The Following 35 Users Say Thank You to arsikhanarsi For This Useful Post: |
09-19-2017, 12:51 | #2 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Negeri Para Penipu
Member: 142211 Status: Offline Thanks Meter: 90 | YES U are right Sir UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-J500F Selected port: Software version: 28.1 Searching Samsung USB Flash interface... COM3 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.1 |
The Following User Says Thank You to not2link For This Useful Post: |
10-17-2017, 09:18 | #3 (permalink) |
Freak Poster Join Date: Dec 2007 Location: india
Member: 647550 Status: Offline Sonork: 100.1611449 Thanks Meter: 31 | Operation: Reset FRP/React/EE Selected model: SM-J500F Software version: 29.4 Searching Samsung USB Flash interface... COM17 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.4 |
The Following User Says Thank You to inderpreet123 For This Useful Post: |
03-14-2018, 19:35 | #10 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2816500 Status: Offline Thanks Meter: 3 | Samusng J500H FRP Bypass Done By Z3x Operation: Reset FRP Selected model: SM-J500H Selected port: COM42 Easy Jtag Control Port Software version: 26.9 Waiting ADB device... OK Reading phone info... Model: SM-J500H Android version: 5.1.1 Product code: SM-J500HZKDINS Phone version: J500HXXU1AOFA PDA version: J500HXXU1AOFA CSC version: CSC country code: CSC sales code: HW version: MP 0.400 Phone S/N: RZ8G805E49K Modem board: MSM8916 RF cal date: 2015.08.08 IMEI: FRP Bypass APK Remove... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.26.9 |
The Following User Says Thank You to almaskhan For This Useful Post: |
03-28-2018, 15:26 | #11 (permalink) |
Freak Poster Join Date: Mar 2014 Location: PAKISTAN
Member: 2145475 Status: Offline Thanks Meter: 100 | Thankssssssssssssssssssssssss to arsikhanarsi sir Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.9 |
The Following User Says Thank You to azaanali For This Useful Post: |
03-31-2018, 08:52 | #12 (permalink) |
No Life Poster Join Date: Jun 2012 Location: bhopal
Member: 1778370 Status: Offline Sonork: sujan_goa Thanks Meter: 66 | Searching Samsung USB Flash interface... COM21 detected Selected model: SM-J500F Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.31.0 |
The Following User Says Thank You to p.k510 For This Useful Post: |
