05-19-2019, 20:23 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: PCB
Member: 2320407 Status: Offline Thanks Meter: 88 | Faild to Unlock S7 G930T U9 Bit9 (with TMB Server) HELP CAN'T DOWNGRADE To unlock: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G930T Selected port: COM130 SAMSUNG Mobile USB Serial Port Software version: 36.2 Checking Login and Password... OK Ballance: 10 crd. You have 10 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G930T Android version: 8.0.0 PDA version: G930TUVS9CSB2 CSC version: G930TTMB9CSB2 Phone version: G930TUVS9CSB2 Product code: Not Active CSC country code: USA CSC sales code: TMB Phone SN: xxxxxxxxxxxx IMEI: xxxxxxxxxxxxxxxxx HW version: MSM8996.00 RF cal date: 2016.02.24 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2019-02-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM9 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (1) Done with Samsung Tool PRO v.36.2 |
