09-26-2017, 04:25 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Jamaica
Member: 383592 Status: Offline Thanks Meter: 88 | SM-G570Y new security unlock error [Solved] Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G570Y Android version: 6.0.1 Product code: SM-G570YZKDXME Phone version: G570YDXU1AQD1 PDA version: G570YDXU1AQD1 CSC version: G570YOLB1AQD1 CSC country code: MALAYSIA CSC sales code: XME HW version: MP 0.500 Phone SN: R58J63KGQDA Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-04-01 RF cal date: 20170616 IMEI: 35xxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 23) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung To Need help unlocking this phone... |
09-26-2017, 16:41 | #2 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Mongolia
Member: 2022955 Status: Offline Sonork: 100.1646687 Thanks Meter: 418 | Modem : CP_G570YDXU1APK2_CL9756867_QB11497825_REV00_user_l ow_ship.tar.md5 Firmware: XME-G570YDXU1APL4-20161228082843.zip Sec: U1 |
The Following 4 Users Say Thank You to huaweinckunlock For This Useful Post: |
09-27-2017, 02:27 | #3 (permalink) | |
Member: 383592 Status: Offline Thanks Meter: 88 | Quote:
Operation: Unlock Selected model: SM-G570Y Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: SM-G570Y Android version: 6.0.1 Product code: SM-G570YZKDXME Phone version: G570YDXU1APK2 PDA version: G570YDXU1AQD1 CSC version: G570YOLB1AQD1 CSC country code: MALAYSIA CSC sales code: XME HW version: MP 0.500 Phone SN: R58J63KGQDA Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-04-01 RF cal date: 20170616 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 23) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Modem board: SHANNON305 HWID: B9 AD 6D 8B 94 81 B9 84 89 6F 80 E0 0A 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29 | |
10-14-2017, 07:12 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G570Y Android version: 6.0.1 Product code: SM-G570YWDDXME Phone version: G570YDXU1APK2 PDA version: G570YDXU1AQG1 CSC version: G570YOLB1AQG1 CSC country code: MALAYSIA CSC sales code: XME HW version: MP 0.500 Phone SN: R28J6162DNK Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-07-01 RF cal date: 20170610 IMEI: 3534220832 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 13) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Modem board: SHANNON305 HWID: CD 9B 28 A2 36 50 80 8B 4B 3A 07 8E 0A 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.5 |
The Following User Says Thank You to dky_tel For This Useful Post: |
08-25-2018, 10:58 | #5 (permalink) |
Major Poster Join Date: Apr 2008
Member: 742687 Status: Offline Sonork: sunilbansal Thanks Meter: 21 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Unlock Selected model: SM-G570Y Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: SM-G570Y Android version: 6.0.1 PDA version: G570YDXU1APL5 CSC version: G570YTNX1API4 Phone version: G570YDXU1APK2 Product code: SM-G570YZKATNX CSC country code: New Zealand CSC sales code: TNX Phone SN: R28HA36LYHF IMEI: HW version: MP 0.500 RF cal date: 20161027 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2016-09-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Modem board: SHANNON305 HWID: 3C 72 26 87 09 DF D7 AD 63 F9 B4 3C 0A 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.5 Last edited by sunilbansal; 08-25-2018 at 10:59. Reason: with cf auto root in odin |
The Following User Says Thank You to sunilbansal For This Useful Post: |
09-18-2018, 01:24 | #7 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2380654 Status: Offline Thanks Meter: 0 | Waiting ADB device... OK Reading phone info... Model: SM-G570Y Android version: 7.0 PDA version: G570YDXU2BRC1 CSC version: G570YXSA2BRC1 Phone version: G570YDXU2BRC1 Product code: CSC country code: Australia CSC sales code: XSA Phone SN: IMEI: 000000000000000 HW version: RF cal date: Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2018-03-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 13) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.33.8 pls i need the modem downgrade for this region XSA |
01-19-2019, 14:08 | #10 (permalink) |
Major Poster Join Date: Jul 2010 Location: Richmond
Member: 1351559 Status: Offline Thanks Meter: 14 | I spent a lot of time searching a lower modem for Binary 2 G570Y but unfortunately, it is not available yet. So, it means we can't unlock this model with binary 2 by rooted method. Anyone who failed with rooted method, can try " Reading code via server [NEW] ". Good luck all. Operation: Read Codes via Server Selected model: SM-G570Y Software version: 34.8 Checking Login and Password... OK Ballance: 220 crd. You have 220 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G570Y Android version: 8.0.0 PDA version: G570YDXU2CRI1 CSC version: G570YXSA2CRI1 Phone version: G570YDXU2CRI1 Product code: SM-G570YZKAXSA CSC country code: Australia CSC sales code: XSA Phone SN: R58K54XYPMP IMEI: 355078080893388 HW version: MP 0.500 RF cal date: 20180525 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2018-09-01 Boot Warranty bit: 1 SIM State: ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 96805368 NET lock: 61791797 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# |
The Following User Says Thank You to hoangtrongusvn For This Useful Post: |
